Pen Turning & Spindle Gouge
Sean Troy
>Hey all, when using a 3/8 spindle gouge for pen turning and on a jet mini, how high in relationship to your blank do you present the gouge ? On top, below top, middle or below middle. thanks for the help. Sean
Sean Troy
Re: Pen Turning & Spindle Gouge
Bruce Wiseman
>I set the rest so the gouge is at the center line. Take light cuts working from both ends and try to keep both blanks about the same size so that I can move the tool rest in as needed. If the rest is too high the gouge won't cut and if it is too low you will pull the tool down & under the work. You don't want that. DAMHIK.
Have Fun, Turn Safe.
Bruce
Keith Tompkins
>HI Sean, I think my reply applys to spindle turning in general...I would use a 3/4"continental style gouge for turning a pen blank, as it won't tend to leave ridges like a 3/8"gouge would, so less sanding. I would contact the wood a bit above center to smooth, with the bevel rubbing, and the gouge at an angle to the turning, and rolled so the upper edge clears the turning. In other words, NOT with the handle pointing straight in. A much better cut that way.
Most of my spindle turning is done right on center, but it takes some practice...same technique as above, bevel rubbing, handle very low and braced against my body, again at an angle to the turning. In this way the 3/8 gouge will make an acceptable cut. If you try to turn with the gouge straight in, a scraping cut is going to develop, with poor results.
Any beads or details are done with the gouge on its side, right on center.
RussFairfield
>I know that this is against the "conventional wisdom", but my opinion is that worrying about the tool rest height relative to the horizontal centerline is placing too much emphasis on the wrong thing. There are a lot of factors that determine where we position the tool rest; none of them have anything to do with a physical measurement, and everybody will be different.
We should be putting first things first; and that is putting the cutting edge on the wood, with the bevel rubbing, and the tool handle at a comfortable location for holding and control; and then raising the tool rest to support the tool. Where this will be relative to the horizontal centerline of the wood will depend on the relative heights of the lathe and the woodturner, how we like to view the cutting area, the angle of the bevel, the diameter of the wood, the diameter of the tool, the distance between the rest and the wood. the length of the handle, and our personal preference for how we hold the handle.
An example of how the tool rest height is a personal thing. I use a gouge with a 25-30 degree included angle between the bevel and the bottom of the flute. I like to have it cutting somewhere at about 45-degrees above horizontal on the wood circle. I also like to look down on the cutting tool, and that means my lathe is a bit lower than the recommended elbow height.
Compare this with the opposite, someone who likes having the work up higher and in front of them, turning with the same tool, but with a 45-degree bevel. The tool rest height that makes this happen will be very different from mine.
