Cole Jaws ??? for Supernova Owners? (long)
Lou Krupnick
>Forgive me in advance if this is an inappropriate question for the messageboard, I truly don't work for Technatool. Problem is, I don't have the drill press or time to make a holder to reverse turn the bottoms of my work & looked into purchasing a set of Cole Jaws for my Suernova2 chuck- only to find out that Teknatool's jaws only went up to 10" dia. So, I querried the company to ask if they considered making something that would capture the 12"-14" range & they said there wasn't a market for such. Any thoughts on the matter or work arounds? I'd love to be able to convince them otherwise....
Thanks, Lou K in MD
Re: Cole Jaws ??? for Supernova Owners? (long)
Dave Shombert
Dave Shombert
>Lou,
Vicmarc makes the "Cole" jaws (they don't call them that) in a larger size, I have a set. I think Oneway also does, but I can't swear to it. Maybe Axminster, too. You probably don't want to buy another chuck just to gain this capability, so that brings up the question of whether Vicmarc's jaws can be used on the Nova. I don't know the answer to that, but there's probably someone here who does. Seems like I recall Packard carrying jaw inserts that make this possible - ?? The rubber grippers that come with Vicmarc's version are shaped such that they provide a more secure hold than Nova.
In any case, the cole jaws have their limitations for holding a reversed bowl for finishing off the bottom. I've used both Nova and Vicmarc versions for this purpose, but it's not my method of choice. Tailstock support is usually required, as it is when using a jam chuck, and the latter seems like a lot less fuss and more stable. Buzz back if you want some details on that method.
Dave Shombert
Elkins, WV
GeeSeaWhy
>I have the Cole jaws but use them very infrequently - it's faster to set up the vacuum chuck and also more reliable and versatile. There was an article in American Woodturner Spring 2004 about making wooden jaws to add on to either the Cole jaws or another jaw set (the Teknatool 100mm jaws have holes you could use for this). If I didn't have the vacuum setup I would certainly have tried this approach by now.
Graeme
Brian Gray in Sanduksy, OH
>I don't own a vacuum chuck, and all my bowl bottoms are done with the Nova cole jaws, however, I've altered them.
I took the conventional cole jaws, and attached 2" thick wooden planks to them. I then shaped them so that the were circular on the edges. From here, you can mount it on the lathe to true them up, and the last step was creating some lipped "steps" so I can hold bowls of different diameters without having to change any jaws. So they are now a larger diameter, and stepped.
Let me know it this isn't clear.
Also, I'm guessing that Teknatool doesn't want to make real HUGE cole jaws due to liability. Someone might mount a large cole jaw set at 3000 rpm accidently and hurt themselves.
Re: Cole Jaws ??? for Supernova Owners? (long) *LINK*
Rob Ceraso
>Hi Lou -
I made a set of 20" cole jaws for my Supernova by following the directions in the article linked below. I used them to turn the bottom of an 18" platter on my Jet 1442 and they worked just fine.
Rob
http://www.woodcentral.com/articles/turning/articles_123.shtml
>Lou, I made a set of 8 "hooks" that go in my Cole 10" Nova Cole jaws. I got a piece of steel strap for Lowes or HD about 36" long, an inch wide, and about a 1/16" thick and cut it into eight pieces. I bent one end or each up past 90 degrees. I put a little stop block on my drill press and tried to accurately drill holes through them. (woodworker accuracy here, nothing measured in .000 anything.) I dipped the hooked end into some liquid rubber (Lowes had it) for tool handles) After rounding all the ends off on the grinder. I now use the rubber bumpers to attach them as extensions. They will expand the capacity of the Cole jaws out to about 16". They work great and hold better than the rubber bumpers. I have also turned them around and gripped rings from the inside by expanding the jaws. If the rubber bumpers get in the way I use my spare set of jaw screws and put a piece of tape over the heads to avoid scratches.
Incidentally, I have a homemade vacuum chuck and I find these hooks to be much more secure and quicker. I routinely finish the bottoms of bowls without the tail stock. I do not have that muck faith in the vacuum chuck. I have an older Midi chuck I leave the Cole jaws on all them time just for bowl bottoms.
Steven Antonucci
Oneway Jaws fit a SuperNova
steve antonucci
>I have a set that I bought on eBay and they fit and work just fine. I think they are 14", but Oneway makes bigger jaws. In my opinion, they are much easier than making a jam chuck, and take only a few minutes to switch out on the one chuck I own. I've never had a bowl come off.
Steve
Corrected Link  *LINK*
Garrett in Victoria
DIY Cole Jaws
Keith Tompkins
Keith Tompkins
>Lou, you may not need a drill press if you have a lathe. Fasten a plywood plate to a faceplate, use the tailstock to drill a center hole, then turn the assembly perfectly round while on the lathe. Depending how you wish to attach the plate, a recess for the existing jaws could be turned also, which would center the assembly on the chuck.
bob davis
>look up longworth chuck in wc ardhives,myself and several friends have made this chuck..works great,much faster than cole jaws
