buffing attachment for lathe
ben d.
>Pic's of the buffing attachment that I made to use on my lathe. From end to end it is 33 in. The wheels are 8" the first 2 are cotton and are singles and the flannel wheel is doubled.
3/4 in shaft with morse taper on one end and a center hole on the other to use with a pointed live center. Flat washers and spacers to space the wheels. The spacers are not a perfect fit to the shaft and wobble a little but causes no problem.
Re: buffing attachment for lathe
Curt Fuller
>Nice buffing setup. What did you use to buff that lathe up so clean?
>He has to have been turning on it. Look at the shavings and "spatter" on the back wall :).
Quick question
Garrett in Victoria
>What prevents the washers/wheels from sliding sideways?
Cheers, Garrett
Re: Quick question
ben d.
>Havent had this lathe but about 8 months and just don't have it cruded up yet.Kindly been particular I guess.
#2 morse taper on the drive end then a locking collar secured by set screws then the spacers washers wheels to the other end where it is threaded and double nut-ed to keep everything in place. The center hole on the nut end is large and deep enough so the pointed live center keeps everything in place.
