We value your privacy.
>I have a large amount of punky wood. It is partially chalky and wet. I saw an ad in Lee Valley for Liquid Wood restoration kit and before purchasing I thought a few comments from members of this board would be very helpful. Alternatives also very welcome and appreciated.
I would very likely discard the wood. There is way to much good sound wood to waste time with punky wood.
There could be reason to save punky wood. Some of the reasons I might want to save some punky wood include:
1. Wood of great sentimental value
2. Wood of exceptional color and figure
3. Wood that was of little value but that I wanted to learn how to fix punky wood so that I was able to save the wood mentioned in 1 or 2 in the future.
I have used a product called Get-Rot which crystallized the wood or what was left of the wood. This product is a very thin epoxy which penetrates the punky wood to different depths depending on the condition of the wood. You can likely increase the penetration with some heat, pressure and or vacuum. Still you are not going to be able to stabilize a hunk of wood with the stuff. If you rough turn the punky wood leaving enough wall thickness to turn the stabilized wood past the tearout and damage from the roughing process you MIGHT be able to complete a successful bowl.
>I recently went on the search for some polyall 2000 and when I couldn't find any, phoned the manufacturer. I was told it wasn't currently available due to some manufacturing problems and probably wouldn't be back on the market till sometime next year.
>I've used Minwax Wood Hardener on small punky areas. You can find it in HD or Lowe's, or other stores. It's not real cheap, but it is convenient when you need to get some for that evening or Sunday turning sessions.
