I added a winch to my truck's crane.
Al Crandall (NE of Indy)
>Last year I developed a method of attaching a crane to my truck's hitch receiver. The copyright is co-owned with the AAW. This year I increased the crane's utility by adding an electric winch to it. I can now drag a log section to the truck from 50' away and load it without pumping the handle of the crane's hydraulic jack. The parts were just add-ons; no modification of the stock crane was done.
Re: I added a winch to my truck's crane.
Close up shot of winch mounting.
>The winch is mounted to two sections of angle iron which have 1/4" thick flat stock welded across them. The stock mounting bolts which came with the winch were used. The angle irons have a tab welded to each side with a hole in them to line up with a hole already in the crane arm. To mount the winch, I just straddle the crane arm with the winch tabs, insert a long bolt through the holes, and tighten one nut.
Re: Close up shot of pulley at end of arm.
>The pulley is a 3 1/2" diameter deep vee idler pulley from Tractor Supply. It has a 5/8" ball bearing mount. I stacked three washers of various size and thickness on each side of the bearing to space out the 1/4 x 1 1/4 x 10" flat stock so it was a good fit inside the square tube of the crane arm. I had to notch each piece so they would fit over the stock bolt which holds the original crane chain in place. I used a die grinder to make the notches in the new support arms.
>Weight capacity? Are we talking about 500 lbs with the winch?
Bruce in Saint John, N.B. Canada
>Quite an idea Al, a slick set up for sure. Certainly beats the arm strong method that I use. Going to put this one on my To Do List.
Ya got one Popeye arm????
Terry Quiram, Roanoke Illinois
>Al
Nice addition and a slick solution now that you have one Popeye arm from pumping the lever so much.
Terry
Bill G. will be really jealous of this rig...!!
Michael Stadulis, in rainy Gloucester County, NJ
Re: The winch is rated at 2000 lbs.
>I have the crane set at the 500 lb. length and have increased the length somewhat by adding the pulley supports. In theory this should eat into the 500 lb. rating, but I imagine that there is a safety factor built into that figure. I also don't forsee lifting very many turning blanks which will exceed 500 lbs. I could always collapse the crane arm to the 600 lb. length or the 750 lb. position if I see the arm bending under load. At any rate, I expect the winch to meet or exceed the crane limitations.
Re: Are Pounds per amp a linear rating?
>The max amp draw on this winch is 130A @ 2000 pounds pull. The manufacturer suggests that a fuse or circuit breaker be installed with a capacity of the max amp draw. The largest breaker I could find at the local NAPA store on a Sat. afternoon (Christmas eve) was 50 amps. This is what I put in the + line of the jumper cables which I use to get power to the rear of the truck. I am hoping that the hoist breaker will trip before I overload the crane too much. If the pound/amp ratio is anywhere near linear, I shouldn't be able to lift much over 750 pounds.
Re: Bill G. will be really jealous of this rig...!
Don Henthorn
>Naw. Bill will just pick it up between his thumb and index finge and throw it on the truck. (G)
