>I live in the Calif desert and was given a big load of wood by a local tree trimmer. Not sure what it is but lots of flame detail in rust and brown colors. The odd thing is some areas are really wet and others very dry, even appear spalted. Chalky like. Is it a bad idea to use this wood? I turned a nine inch wide by four inch high hollowform to under 1/4" thick and some areas at the outer perimeter are quite wet as described. Ii'm soaking the piece in alcohol for a couple days hoping that may stabilize the drying. Any suggestions will be appreciated.
>First if you haven't already done so put on end sealer, you should do this asap. I would take a few pieces and chain saw or band saw right down the pith. Afer measuring the diameter, saw some pieces a couple of inches longer and coat again with end sealer. Set aside. You can turn green hollow forms and or natural edge. Seal these with lacquer after the lacquer dries, super glue the piths and watch daily for any cracks. If the pith cracks you can fill with crushed corain, sawdust, metal shavings, coffee, etc. Some finished piece will distort less and crack less, that's just the way it is. Others can give advice on alcohol,oil or soap soak. GT
>I turn wood to completion wet, green or dry. Get your shape done on the outside, sand to up to 380. Put on the lacquer let dry by wiping off and spin dry. After that it's time for super glue the cracks and filling if any. Sand and sheer scrape again if super glue is used. After mounting on the chuck, you may need to tickle and sheer the finish again. Take out any wobble. Apply lacquer again and wipe dry. Now you are ready to do the inside. Get it done to about 3/16". If hollow turned you still need a sealer inside. Again lacquer will do it. Next day check for splits & cracks, fill with super glue and filler if needed. Lacquer. Watch daily, when you think it is dry enough go through a cycle of Tung oil finish sanding between coats. Again this is my way, others will differ. The locust bowl I just finished (and posted) is done as described above. It took a month for completion. At present time in the shop I have 12 or more projects going through described completion process. GT
You should seal the ends of the load of wood you got to keep it from drying out too fast and cracking. AnchorSeal (available in gallon jugs at Woodcraft and elsewhere) is great for this.
To make a turning from green wood and have a lid fit well, I would turn rough, coat with anchorseal, then let dry until it stabilizes before finish turning. I coat all over to slow the drying, but some people coat just the outside, some coat just the endgrain. BTW, if the entire piece was turned with the grain running lengthwise instead of across the piece, you have a big advantage when fitting a lid - small seasonal changes will be much less likely to cause the piece to go out of round.
