wax on a JET mini!
wax on a JET mini!
wax on a JET mini!
Blake Washburn
>A few scrolls down on the page, John Lucas told me that it isn't the best idea to put wax on the bed of a JET mini lathe. What all will the wax help and not help? If it won't help how do I take it off? How do I keep the tailstock and tool rest sliding smoothly?
Blake Washburn
Re: wax on a JET mini!
e
>hi blake:
i don't use wax on bed because it can build-up and create a dust/wax mess. also, if you get the bed too slippery, the tail-stock can be hard to clamp and then slip.
generally, i use WD40 to clean off any rust or corrosion. furthermore, sometimes there is a chemical reaction between the metal of the lathe and the wood. for example, when turning oak, the metal will immediately turn black and tarnish. i'll periodically stop and spray down the lathe to slow-down the tarnishing.
also, a new piece of equipment will usually come coated with a grease. i'll use WD40 also to clean off the guk.
>Blake don't do anything at first. If the tailstock doesn't slip on you then the wax will be fine. If you do find that you need to get it off mineral spirits will take it off. Like e said I use WD-40 to both lube and protect the metal parts. Even if the bed gets a little rusty that's OK as long as the tailstock and tool rest slide easily. Some turners actually purposely rust the bed a little to make the tailstock lock down better. I've never had to go that far.
Ken Grunke from SW WI
>I had our club's General midi lathe for about a year and after a while the toolrest banjo and tailstock got kind of sticky. After cleaning everything with a scotchpad, I used a liquid paste wax intended for auto use, wiping a very thin film on the bed and the underside of the banjo and tailstock. Made a world of difference, and had no problem with buildup because it was a very thin application, and I wiped it down with fresh wax occasionally.
One thing you can do if you have slippage of the locking mechanisms in the tailstock or banjo is lubricate them with white lithium grease. The banjo has a long shaft that moves eccentrically within it, and passes through the end of the bolt going down to the locking plate below. Rub a thin film of grease on that shaft, the full length. The tailstock has a short shaft attached to the locking lever, also going through the clamp bolt. When these points are lubricated, you can get a little more clamping power to the bed, probably enough to avoid slippage.
I wouldn't use grease for the bed as it's sticky and will attract a buildup of dust but the points I recommended for it should be protected from that.
>I put a thin coat of wax on the ways of my lathe (Jet 1642). I use a microcrystalline wax. I also use it on my tablesaw top and my bandsaw. Gentle wipe on and polish it off. I find it keeps down corrosion and makes clean-up easier.
JKJ in East TN
>Same here, Renaissance Wax, available at Woodcraft and most other suppliers. Great on the tool rest, bandsaw table, etc.
I read one "expert's" advice to let the ways get rusty so the tailstock will not slip, but I couldn't do it. Mine do not slip, but if they did, rather than rust I would prefer roughing up the metal to get some grip, then waxing that.
