Treadmill motors *LINK*
Fred in NC
>I am with Bob Lemon on this one!
Treadmill motors are usually permanent magnet 90 VDC, rated at 1 HP or more. A used but working treadmill can supply most of the parts, although the controller will look a bit unusual for a lathe . . .
When I did my conversion, I ordered a new motor pulley from Jet Tools, so I could leave the original pulley and motor intact. I had to bore out the pulley to fit the DC motor. Also, I mounted the DC motor under the lathe, in a cabinet I built for it. This required longer belts, which were ordered from Aarubco Rubber Co. (cheapest and best service, no affiliation).
A an alternative, Surplus Center sells DC motors and controllers at reasonable prices. Their best controller is the Minarik, at about $60, and you would be wise to add heat sinking to the aluminum frame. As for motors, their 130 VDC motors can run on 90 volts, losing about 1/3 of the HP. That will leave about 1 HP which is more than plenty for the mini lathes.
Replace the AT for my email address.
Lathe cabinet
