End grain
End grain
End grain
Don Tewell
>I am trying to turn a cherry bowl for my daughter in law. I am having a lot of problems getting the end grain smooth enough to start sanding. I have taken very fine shearing cuts but not close enough to start the sanding process. Is there a way to prevent tear out? I thought I remembered a thread about using something on the bowl to help alleviate this. Any help will be greatly appreciated. Thanks in advance.
Re: End grain
Re: End grain
RevDoug
>Try waxing the piece. Then you should be able to use a very sharp scraper and take care of the tearout. Make sure you sand out all the wax in the sanding process so that your finish will stick well later.
Turn 'em round,
Re: End grain
Re: End grain
JKJ in East TN
>I generally apply a coat of something - Myland's sander sealer works well. Some use CA glue but that is expensive and can make things splotchy. Soft wax, oil, or even water can also work.
Also, I find cabinet scrapers good for cleaning up tearout, curved scrapers for the inside, straight for the outside. I use these held in my hands without any kind of tool rest. This seems better than shear scraping, at least for soft woods like easter red cedar and buckeye.
Re: End grain
Re: End grain
Wally Dickerman in Arizona
>Don, it's very important that your final cuts be made cutting with the grain. When cutting against the grain you are cutting unsupported wood fibres, which accounts for the torn surface. You could compare that with planing a board in the wrong direction. If the piece you're turning is face grain, cut from small dia. to large. If it's an end grain turning cut from large dia. to small.
Before sanding, clean up damaged surfaces with shear scraping, done very lightly, and also done with the grain.
Wally
Re: End grain
Re: End grain
GaryG in MD
>Wally,
Please correct me if I'm wrong. For facegrain, when you say to cut from 'smaller to larger', it seems to me that's true for a convex surface (the outside of the bowl). Isn't it true, though, that for a concave surface (if you're on the inside of the bowl), you want to go from larger to smaller?
Always fighting tearout,
Gary
Re: End grain
Keith Tompkins
Re: End grain
Keith Tompkins
>Don, I find cherry usually turns well, leaving no noticable tearout in most cases. Make sure tools are sharp, esp. the final cut, which should be done with a freshly sharpened gouge. I roll my gouge into the cut to present the cutting edge at a 45 degree angle to the surface...risky for a catch, but a clean cut.
Re: End grain
Re: End grain
Don Tewell
>Thanks to all. I guess tonight I'll try a combination of things. I've not had this problem with cherry before either. Maybe just a punky piece of wood.
Re: End grain
Re: End grain
>True....for a face grain bowl, when turning the inside, you cut from the rim toward the bottom. That's cutting with the grain.
Wally
