My Jet Midi Lathe arrives tomorrow
Arw01
>As the subject says, the Birthday present from kids and wifey arrives tomorrow. It will remain to be seen if I get my present early or have to wait for Sunday.
The question is what inspection and setup should I do first besides the chinese to japanese to korean to english transcribed instructions tell me?
Meant to pick up a set of Windsor designs chisels to play with over the weekend so they would be sharp, have to make that trip later I guess.
Thanks
Alan
Re: My Jet Midi Lathe arrives tomorrow
Mark Wollschlager
>It should be ready to go out of the box. Fully assembled.
You just need to remove the faceplate from the spindle, knock out the spur center and live centers and give the whole thing a wipe down to remove the packing grease.
I used kerosene on a rag to wipe mine off. The morse tapers in the head and tail stocks also are coated with oil/grease and can be cleaned out.
You also might want/need to clean up the top and front edge of the tool rest.
Mine was a little bumpy and the black paint flakes off.
A few strokes with a file or a bit of sandpaper will do it.
Enjoy!
Mark.
Blake Washburn
>I recieved my JET mini lathe for Christmas. My neighbor told me to use steel wool to clean off the sludge and grease on the lathe. While cleaning apply WD-40 and wipe off with steel wool. To finish it off you should pup car wax on the whole lathe for two reasons:
1) It will let your tailstock and tool rest glide on the bed smooth and easy.
2) It will help you keep the cream colored lathe keep its color. If you get any smudges on it, all you do is get some steel wool and clean it off.
Another thing, cleaning your lathe is not a one time thing. You should maintain the cleanlyness on your lathe every so often.
Blake Washburn
Blake Washburn
>I recieved my JET mini lathe for Christmas. My neighbor told me to use steel wool to clean off the sludge and grease on the whole lathe. While cleaning, apply WD-40 and wipe off with steel wool. To finish it off, you should put car wax on the whole lathe for two reasons:
2) It will help you keep the cream-colored lathe keep its color. If you get any smudges on it, all you do is get some steel wool and rub it off.
Blake Washburn
David Sophusson, Custer Wa.
>Hi Alan,
Besides the cleaning and making sure everything works properly you should order or obtain an extra belt or two. When my first belt broke I found out that it took a week to get a new one so I order them 2 at a time and I�m on my third one now. Also unless they changed something the three quick clamp handles are really wimpy and break easily. I went to Grizzly�s and picked up 3 new ones for about $2.80 or so each. It�s been awhile back since I bought them but I believe the size was 8mm. The one for the tail stock I had to grind the end to match the old one but it was no big deal. If I remember right I also had to cut the one for the belt tension because it was too long. Other than that it�s been a really good lathe and I�ve got a lot of hours on it now, in fact I use it way more than my big Delta.
Sophie, wishing I could send all this rain to Texas.
>Boy you must be hard on a lathe. I have yet to break anything on mine. I just sold an older one that I had used for demos for 3 years and the belt still looked new. I have one of the new white machines now.
>Blake Waxing the bed on the jet mini may or may not be a good idea. These lathes have always had a problem with the tailstock slipping. Waxing the bed sometimes makes it worse. It does keep the rust down. That's what I do to my big lathe. For the Jet I just wipe it down with WD-40 and then wipe it off. It seems to be working but I am currently designing a new clamping block for the Jet mini. When I get it built and tested I'll post it on this board. It should stop the problem of tailstock creep but that's only in theory. I haven't had time to build it and test it yet.
Actually Dave Smith busted one :-)
>Hi John,
And someone else broke another at the same BBQ one year so you can ask Dave it didn�t take much to break off the handle. In time I probably would have broken them myself like I said they used to be really wimpy. I haven�t checked a new Midi out for a few years so I don�t know if the handles are still the same or not that�s why I was asking. As for the belts my little Midi gets a fair amount of use especially during BBQ time. :-) But for a machine with a half horse induction motor the belt is way undersized especially when turning near full capacity.
Sophie
Re: Actually Dave Smith busted one :-)
>Dave I've seen a lot of the short tool rests break. We were getting ready for a demo one day and I was showing another turner how to control the gouge and the tool rest just broke. No real force was applied to it. Fortunately we were demonstrating with a blacksmith so he made us a new tool rest. Boy those guys are handy to have around.
