sanding bowls
sanding bowls
sanding bowls
Patrick Capobianco
>Can someone please explain the sanding process? Do you use the power drill with the lathe running or stopped? And is this mehtod the best way to sand a bowl, any suggestions would be appreciated.
Re: sanding bowls
Re: sanding bowls
T Daniel
>Patrick, there are as many ways to sand as there are turners. This is how I do it:
If the bowl or vessel is not a natural edge I power sand the bottom of the vessel to get rid of the nub, then I sand the rest using my finishing oil and Norton 3X sandpaper, starting with the coarsest grit necessary and working my way to 400. I wipe the oil off between grits, somnetimes wiping only between 2 grit size changes. If I see small ridges that my gouge left I remove those with a cabinet scraper. When I finish sanding with 400 grit I wait a few minutes then wipe dry. In a few days the oil will harden and I start back with 400 grit and work my way to 2000 or 2500. All this is done with Watco Danish Oil. After all the sanding is done I may switch to a faster drying oil and continue until I have the gloss that I want. I use 0000 steel wool between coats of finish.
If the vessel is natural edge or has large voids where handholding the paper while the piece is spinning is not practical then I will power-sand with the piece without oil. Again, go through the grit sizes. Wear good dust protective gear when dry sanding. When power sanding you will generate a lot of heat so you must be careful to not overheat the wood and the rubber pad which holds the paper. A lower rpm works just as well as a higher rpm and does not burn your work or your pads so much. If power sanding use a protector pad between the sandpaper and the rubber pad so that if you get too hot and burn the hook & loop off you can replace the protector pad instead of the whole arbor and pad. I could go on and on with this topic; it can easily become an all day demo.
TD
Re: sanding bowls
Re: sanding bowls (long)
>Patrick, I think you posted this before and got a joke for an answer. Hope your were not offended, but I can see how it failed to answer your question. The answer is that each of us does what works for us.
Generally, I power sand, using a crappy Dewalt Drill. Its a regular drill with a key less chuck I bought for about $29. To be honest, I use it because I hate it. The shuck is a piece of crap and I am abusing the drill to death. If the SOB would have the good graces to die a certain death, I would have an excuse to replace it with something I might like better. Such as a Milwaukee or Sou ix Electric angle drill, although after all the posts about them having crappy switches and poor bearing, I might have to rethink a $150 drill for a 429 job.
So, I picked up the drill i had and bought some Velcro sanding disks through the turning club I'm in and some H&L sanding disks in various grits and had at it. With the piece still mounted in the chuck I sand the inside and about half the outside. I start with some embarrassingly coarse sand paper and sand out the tear out. I lock the spindle and grind the torn spots into submission, usually with 100 grit. Sometimes I take another whack at shear scraping or a final light pass with the tool of choice. Then I go to 150 grit and either let the lathe free wheel and power sand or turn the lathe on slow and power sand. I do very little sanding any more just holding the sand paper in my hand, but I used to do a lot. I move upward through the grits. 150, 220, 320, 400. I find I spend more time with the first one getting the last of the tool marks out. I also find that if you are not careful you can seriously damage a bowl sanding it, especially soft wood. You should not use sand paper any longer than necessary. When it becomes dull or clogged you should throw it away unless you can clean the clogged stuff. Really sharp sandpaper cuts and level the surface much better than dull stuff. Dull sandpaper leaves the harder areas and digs out the soft parts of the wood. This is especially true for spalted wood or any wood where the growth rings are far apart or there is a dramatic difference in the hardness.
Partially for that reason, I like to sand with the lathe running. You can drive the bowl with the sander, but I find it has a tendency to sand away the softer wood worse that if the lathe is spinning the wood and you are gently applying the sander. You can maintain the shape and "fair" out the places where you sanded the stubborn grain.
The purists here will tell you they can cut so cleanly that they start with 320 or 400. Good. Excellent if they can, but I bet some of them have a stash of 80 grit for those rare stubborn pieces of grain that defies even the sharpest edge. If you start with 150 or coarser, you must be careful not to ruin the flow of you bowl or reshape it with the sander. OTOH, you must use the sander to maintain your design.
Bear in mind that once you sand something, after the first grit, all you are doing is removing the scratches left by the previous sandpaper.
Once I have the inside of the bowl sanded and about half the outside, I reverse chuck it, either in Cole jaws or a vacuum chuck or even on a jam chuck and finish the bottom and then finish sanding the out side. If I use a jam chuck and leave a little nib at the live center of the tail stock on the bottom, I sand as much as i can of the out side and then remove it and remove the nib, usually with a chisel and either hand sand the spot or put on of the sanding disks in my drill press and sand the bottom.
Some people report they sand their bowl off the lathe. I would like to see them do it. I can not imagine how that could be as "efficient" as power sanding on the lathe, Unless you only have one lathe and someone else is sanding while you are turning the next one. Perhaps that slave should whack you on the head and make you buy them a lathe.
If the bowl is mounted on the lathe and you sand either by hand or power sand or sue one of the free wheeling inertial sanders. you will have some scratches that run across the grain, in fact just about all of them will. I have been known to hand sand enough to leave the last and finest set of scratches parallel to the grain.
Now you have to decide how far you go with this. 400? 600? 1500? Be my guest. Then there are the buffing systems. If you are sanding hard fine grained wood like Cocobolo, 1500 may be just fine, but it's probably wasted on spalted poplar or pine.
I have started to include my dust collector in the process. I put a pickup as close as I can without getting the way and try to direct he flying dust into it. Not only do I breath better, I think it might keep the sand paper cleaner longer.
I hope others will answer. There will be as many answers as there are turners. Some will be great and we will all learn something and some of them will be idiosyncratic and leave us scratching our heads. What I described is not THE way, its just what I do. Pick out the parts that work for you and use them.
Re: sanding bowls
Re: sanding bowls
>Personally I start with 80 grit at a low to medium lathe speed and then proceed up the grits (80, 120, 200, 320, 400, 600). Mostly I use an old Sears 3/8" drill that I hope will die one day soon, so I can toss it and start working my way through my stepfather's stash of drills (he left me several). Hook and loop sand paper. Buy the disks or cut your own.
Sears makes a three head disc sander (3D Sander) that I got a few years back as a present. It works well for spindle work and for the outside of bowls. It doesn't work too well for the inside of bowls. I mostly do spindle work anyway and it works great for that.
Re: sanding bowls
Re: sanding bowls
Dawn Adams
>The best advice I can give you is to purchase Russ Fairfield's video/DVD on finishing (sanding is included). I am only through 1 of the 3 disks and have learned so much already. I am setting aside about a half hour each night to really watch and learn. Thanks, Russ! This was one of the best Christmas presents I have ever bought for myself!
Re: sanding bowls
Re: sanding bowls
Allen Neighbors
>Patrick, keep in mind, this post is from a guy who is now living on a fixed income... (that means I'm poor as a country Church mouse) and I'm also a novice turner that's had to make most of my own tools.
I made some sanders out of roller blade wheels (they're about 3" diameter). Here's how: epoxy a 1/4 inch allthread in the center of the wheel bearing (be careful to NOT glue the bearing) (and put a 45 degree bend 1" from the end of the allthread first.. this makes the handle offset) and drill a 1/4" hole in some 3/4" dowel and glue it on for a handle. Then I epoxy a 3" disk of dense foam rubber (from an old shower shoe) onto the wheel. On that, I epoxy velcro (loop side) to take 3" H&L discs. With the lathe turning about 500 rpm, I sand the outside, (and inside of 6" and larger bowls) by holding the disk just a little bit slanted, and they sand like a power sander. They really work well, about two passes with each grit (moving slow) does the trick some of the time, sometimes three or four passes. Maybe you can see the sanders clear enough in the enclosed picture to clear up my blurred explanation. I use 60 grit when necessary, then move through 80, 120, 150, 180, 220, 320, 400, and finer grits as necessary to please myself with the smoothness. After removing from the lathe, I sand with the grain with the last grit used. I also use 0000 steel wool between finishes. Sometimes I wet sand a salad bowl finish with 400 and higher and then buff.
Hope this helps a little. Al
Re: sanding bowls
Re: sanding bowls
jared
>remove 1 for email
Congrats on some nice work making sanders with low investment. I bought some velcro sanding pads for my drill a while back. When the velcro went to pieces, I bought a roll of velcro from walmart. IT was coated with self stick adhesive. I belt sanded the old velcro off and used epoxy to glue the new velcro on. IT has lasted a lot better than the original material. Jared
