Link Belt for Drill Press?
Jeremy Sullivan
>For the past 7 or so years I've had my eye on Link Belts, but haven't felt the need was there so much. I have a Jet floor "mount" drill press which vibrates more than any other "expensive" tool I own, and with the finer and finer work I'm doing, I think it's time to seriously consider link belts for this this one. Does anyone have experience putting link belts in their full-sized drill press, and is the difference worth the $35 I would need to spend (Rockler's price)? Thanks!
- Jeremy
Re: Link Belt for Drill Press?
Yup...
Peter Teubel
>I've replaced the standard belts on almost all my shop equipment with link belts (including the drill press). Makes a big difference.
Chris In W. MI
>Try running it withouy any belts first. Some motors are the cause of the vibration. If it runs smooth without belts then linl belts will help.
>Jeremy I replaced the belt on my table saw with a Link belt. I saw no difference whatsoever. so the jury's still out for me.
Re: Link Belt for Drill Press? *LINK*
>Jeremy,
I use link belts on several of my machines; JET Drill Press, 18" bandsaw, 6" jointer. I've used both the red "Fenner" brand and the green Harbor Freight product and notice no difference in use or wear. The HF flavor is les$, however, see link. They helped the press and the bandsaw; not much, if any, difference in the jointer. Remember that you'll have to remove a link or two after the belt "wears in" [read - stretches] a bit. With a 3-belt drive on the cabinet saw, I decided to go with "AX" notched belts which are matched and smoother still.
The link belts are especially useful where a belt breaks or wears on a machine like a bandsaw that needs some disassembly to replace the belt. You simply measure the old belt and match the length in links, take off one link, put it in, and complete the last link without having to take the wheel or blade off.
I briefly tried one on my old JET 1236, but the reeves drive didn't like it; very noisy.
Mark
HF-Link Belt
I Agree with John
>I put machined steel pulleys and link belt on my TS (an old Delta Rockwell Contractors saw) and it fine, but I see no actual difference in performance or noise or smoothness of cut. I really did not expect much and did not get much. It was the "anti vibe" kit from Woodcraft.
If I were inclined I would try the DP without the belt and I would flip the belt and run it backward to see if I could hear or sense any difference.
e
>my 18+ yo drill press' performance was greatly improved by replacing the belts with the link-belt. it is also on the ts.
worth the investment -- instead of getting pre-set lengths, i bought the links in 6" increments.
Don Henthorn
>You might go to the local bearing and drive store and try a cogged belt. Will do about the same job and be much less moola.
Jeremy Sullivan
>Thanks to everyone for your input. I can see one's experience with table saws would be less dramatic, since table saws dampen so much vibration just by way of their own mass. But that's where the drill press suffers.. anyway I'm going to take all of the above suggestions and see what comes of it. I'll report back when I get a chance.
