REAL MILK PAINT
? Baldor Grinders & Wolverine Jigs
Jim J. in TX
>I have a very nice smooth running 8" Baldor slow speed grinder, that I would like to use with a Wolverine Jig. The problem is that the cast iron wheel guards project way lower than the recommended 6.25" recquired for the jig. I am sure that another turner has encountered this problem before, and would like to hear how they successfully adapted the setup. I have done a search of the archives - to no avail. Many Thanks to those who have previously shared their knowledge on this board, making it a wonderful resource.
All the Best for the New Year. Jim J.
Re: ? Baldor Grinders & Wolverine Jigs
Dave Shombert
Dave Shombert
>Hi Jim,
I had the same problem, with slightly different dimensions, with my 7" Baldor/Wolverine setup and solved it as follows: The grinder and jig are all mounted on a platform that is a laminate of two layers of 3/4" plywood. That is to say, the grinder sits in the middle of the platform and it (the platform) extends to either side, with the Wolverine base pieces - whatever ya call those things - also screwed to the platform under the wheels. I cut strips of trim about 1/8" thick and 1/2" wide to fit under the edges of the grinder base and glued them to the platform. Thus the grinder sits on the strips and they raise it above the platform surface by the amount needed for the wheel guards to clear the jig.
Hope this helps. If it isn't clear, let me know and I'll email you a photo.
Dave Shombert
Elkins, WV
Barry Turner
>Use a spacer block made from 3/4" plywood to raise the grinder enough to provide clearance for the Wolverine tool bases.
Larry In Lima
>Dave, I have just purchased the Wolverine setup, and also have a 7" Baldor grinder. I'd like to see a couple pictures of your setup if you don't mind, and could email them to me? Thanks, I'm looking forward to getting it set up here, and sounds like you have already done exactly what I want to do. Larry
Buddy Booker
>Ditto on the last response guys. Ironically I just worked on mine yesterday. I just used a piece of 3/4" MDF the size of the base, drilled holes to match the ones on the grinder and bolted it down.
