Veritas - Innovation in Tools
Centering work in vacuum chuck
Jorge Castaneda
>Maybe this question came before, but I did not remember seen it:
I have a number of pieces that were turned in a faceplate and glue block and now need to be reverse mounted to finish the side were the glue block and faceplate still are, what a fellow must do to center those pieces?
TIA
Jorge
scartching my head in Stonington...
Re: Centering work in vacuum chuck
Stuart Johnson
>I have MT with 1-1/4 x 8 threads that I screw onto the face plate. Stick it in the tailstock and move it forward to the vacuum chuck. I then use a saw to finish where I had almost parted off. There might be better ways but this is easy and works for me.
Jorge Castaneda
>Thanks Stuart,
That sounds good to me, where did you get the gizmo?
Bill Howatt
>Jorge,
I made a wooden spindle with a Morse taper on one end and a diameter on the other end that would just allow my faceplate to just fit over. Put the Morse end in the tailstock put the faceplate with the bowl still attached on the other end and slide the tailstock/bowl up to the vacuum chuck and turn it on.
I have improved the above by buying the bushing that matches the thread in my Oneway chuck. The bushing screws onto the threaded end of my Oneway live center in the tailstock and the chuck with bowl are then brought up to the vacuum chuck. Because of the better tolerances I find this works a little better than my turned piece above.
Bill
Bill Howatt
>Should have mentioned it doesn't matter whether you are using a chuck or a faceplate, the threads/size opening are the same.
Bill
Bob Hackett(Mainely,Bob)
>The easiest way I know is to use the end of the toolrest as a pointer to indicate where the high and low spots are and adjust till the space is even all around.In the case of an out of round piece just make sure the gap is averaged out over the entire piece.
It helps if you set the initial vac chucking by putting the tailstock in a center mark that you put on the glueblock at the start of the project.Unless I fix the glueblock on a screw chuck (as opposed to a faceplate)I forget this step alot more times than I`d like to admit.
Have you made the jump up from the Nova yet?
Mainely,Bob
>Often, I just do it by Eye. I put the piece on and fiddle with it until it runs true. Sometimes this is easy and sometimes it just doesn't happen. I use the edge or end of the tool rest as a guide.
I also have home made face plates that have a small hole I drilled in the center. I made a punch out of a nail that I pass through the hole and prick the back of the piece.
I also made a long punch that will pass through the headstock and will prick the back of the block through a chuck or faceplate with a large hole. The chuck has to be open enough to let the punch through.
Then I use the tail stock to line them up as the others have mentioned, once I have the hole.
Also, if I turn a chuck foot on a piece, I leave the center mark on it for this purpose.
Re: Centering work in vacuum chuck *LINK*
John U - Charlotte, NC
>I use the tailstock adaptor from BestWood Tools, but I didn't know about the adaptor Oneway makes for their live center when I bought it. The one from BestWood tools does not rotate like the Oneway adaptor on the live center does.
http://www.store.yahoo.com/bestwoodtools/tailchucad.html
http://www.oneway.ca/spindle/live_center.htm
Best Wood Tools Tailstock Adaptor
Here are some options...
David Propst
>Hi Jorge,
I have one of these Tailstock Chuck Adaptors from Packard which works great. It does not rotate, so it is only for positioning.
Oneway makes this Oneway Center Adaptor for their center, and it rotates.
These Faceplate Center Markers from Don Pencil also look very handy, especially for work turned on a faceplate and dried before finish turning. I plan to invest in one soon.
Best Regards and Happy New Year!
David
Jorge Castaneda
>Hi David,
i think I will go with the packard tailstock chuck adapter, some of my pieces are in faceplates and some in faceplate rings, meaning that I have to mount them on a chuck, that adapter will take the guesswork out of the picture.
Thank you very much
Jorge
Feliz y prospero ano nuevo!
Jorge
You guys are the best! Thanks
Jorge Castaneda
Stuart Johnson
>Looks like you have already received a bunch of places to order an adaptor. I don't remember where I bought mine but it doesn't move. It works great for postioning rings for segmented work as well as positioning for the vacuum chuck.
Ed Karch
>I just use the large cone on the tail stock and bring it up to the face plate while hand rotating the spindle.
>Jorge Even with the tailstock adaptors things don't always mount perfectly true. Pretty darn close but not perfect. I just didn't want you to panick when you get one of these things and they seem to be off. I'm not sure exactly why. I've checked the accuracy of my tailstock alignment and the runout on the live center adaptor and on my chucks. I have the Oneway adaptor to the live center and the Bestwood tools morse taper adaptor. Neither one gives perfect alingment all the time. I'm guessing it has to do with the wood because I can't measure the problem anywhere else. I thought possibly the slop in the threads was the problem but if you bottom the chuck or faceplate out against the adaptor face that should take care of that problem.
Jorge Castaneda
>Thanks for the heads up John, I spent a long time this morning by trial and error and was not able to center the piece, so I hope the tailstock adaptor will do better than me.
Jorge
Dinyar Chavda
>John, I found the same thing--nice to know it's not just me! Sometimes the piece centers perfectly almost right away (I use a method similar to Ellsworth's approach with jam-chucks), and sometimes it just won't center, despite cursing in all the languages I know! :-)
Sometimes it's just because of the movement of the wood, and there's niothing you can do about it, Jorge. What I do at such times is set the lathe to turn very slowly so that the gouge can ride on the piece despite it not being perfectly round, and basically feather a transition connecting the original turned shape to the desired base (if that makes any sense).
Jorge Castaneda
>Dinyar,
Yes it makes sense, thank you!
Jorge
Ron in Drums PA
>When I start, I use the tail stock with a live center as a clamp to glue a block on the turning. This, as we all know, leaves an indentation in the wood.
I use the same indentation latter on, using the live center again to help align the bowl with the vacuum chuck.
Jorge Castaneda
>Ron,
That makes lots of sense, I will remember it.
Thank you.
Jorge
Buddy Booker
>Hey Jorge,
I mount the piece on the chuck as close as I can, apply only enought vacuum to hold the piece on. I then move the tool rest up close and tap the piece with a rubber mallet on the high side until it's centered. Works great.
