Re: alcohol drying problems
Mike Schwing from Md.
>Jeremy, there is no science/rationale that I have seen behind the idea that an alcohol soaked bowl (no matter the type) will crack less than an untreated bowl, given the same conditions. In fact, in my meager little science starved brain, I come up with the analysis that it would cause them to crack more rather than less if the bowl was not soaked long enough to replace nearly 100% of the water with alcohol. How long does that take? Nobody really knows, I think.
The thing that causes bowls to crack when drying are moisture differentials and sapwood/heartwood, which shrink at different rates as they dry. Assuming you had no visible sapwood in your bowl, (or no heartwood), it probably cracked because the outside dried MUCH faster than the inside. This will happen on a thicker bowl more easily than a thin one as it cannot stretch/warp/resist the forces causing shrinkage on the oustide vs the ones keeping it in status quo on the inside.
A water soaked bowl (fresh cut) dries as it starts to evaporate from the exposed ends. As that water on the outside evaporates, it draws water from further inside towards the outside surfaces by capillary/osmosis methods. If a bowl has been soaked in alcohol but it has not been long enough to replace ALL of the water, I _think_ what happens is that the alcohol evaporates very, very quickly compared to the water in the deeper reaches of the bowl and the shrinkage differential is too great to resist cracking - CRACK! The problem is in knowing when all of the water has been replaced.
I'm not a proponent of this method, but I have used it with success as an experiment. After a while of roughing out 3 or 4 bowls per month, you have 3 or 4 bowls every month coming dry and ready to finish. The additional thing I do not like about this method is that it seems to produce blanks that are strange feeling, turn like rocks, and seem to have all of the natural oils stripped from them. They just don't seem as "alive" to me. I also don't like having large quantities of alcohol in the house that I can't drink.
