Antler pens
ChuckS
>Blake, most of this is a repeat of what's already posted, but here goes.
1. Lay the pen tubes you will be using along side the antler & mark where to cut the antler.
2. Cut a little (3/8ish) long
3. Mount between centers on lathe & adjust so you can later drill without breaking out of the side & still have enough wall thickness. I do this by turning the lathe on & holding the pen tube near the rotating blank. Adjust as needed.
4. Rough the blank- still between centers. This is give you a true surface on the sides of the blank so you can drill. True up the ends if you want, but leave long. (I don't bother)
5. Drill. I drill by chucking the blanks in my lathe & mounting a drill in the tailstock. I also drill wet-- less dust & cooler running. Heat is BAD for antler. If I use my drill press, the antler tends to grab the drill & force the drill into the blank.
6. Trim to size with pen mill. Again, I do this wet.
7. Turn like plastic. Sharp tools, light cuts. If you cut into the softer layers, flood them with CA & continue.
8. Sand carefully, heat is BAD. I sand wet to 1500, then use plastic polish.
9. Finish, or not. I like to leave antler unfinished if I have not gone into the softer layers. It will polish beautifully, and over time will develop a patina from the user's hands. Fill any soft areas with CA glue, sand, & polish. If it's mostly soft, just finish with CA.
Work slow, try not to produce dust, & don't breath it. Antler dust is BAD.
All the hassle is worth it, the pens will be beautifull!
Have fun!
ChuckS
