Oneway braking resistor
tombuchner
>Has anyone here installed one of these on their Oneway?? I got mine yesterday and would like to install it. The drive box has two posts, one labeled B1(+) and the other B2. The resistor has a black wire and a red wire. Which wire is considered (+)? Does it matter??
The resistor came without instruction which leads me to bleive it is not critical. But, I don't want to mess up the machine.
Any help is appreciated.
Merry Christmas!!
Tom Buchner
Re: Oneway braking resistor
Dennis Gooding
>Tom,
I am not familiar with the the Oneway braking resistor, but I can assure you as an electrical engineer that if it IS just a resistor then it will not matter which way it is connected. Dennis
Bill Howatt
>Dennis is correct. But if I were to put it on I would put the red on the terminal marked (+) and the black on the other since common convention is that red is +, well sort of, usually :)
Bill
I don't know if this is dumb but...
Bill Howatt
>After I posted I went to the Oneway site to see if they had a picture or more info and I found this:
"Does it need to be factory installed?
The braking resistor should be factory installed because it needs a different drive. To use a breaking resistor the drive needs a brake chopper circuit to be built in. This adds considerable cost to the drive, the braking resistor itself is cheap and easy to put in."
Does this mean you bought a new VFD controller too or does yours have the "chopper circuit"?
Bill
Re: I don't know if this is dumb but...
tombuchner
>Thanks for the help Bill. I have an older Oneway, #646. I have the original drive that includes an area to add the breaking resistor. Per Kim at Oneway I am lucky because they changed the drive shortly after my lathe was produced. So I have the drive they use when they factory install the braking resistor. If you don't have it installed at the factory today, you get a drive that will not have the space for the braking resistor. A way to save money on their drives I suppose.
Thanks again,
Tom
