Re: Oak dish *LINK*
RussFairfield
>You have a good outside form.
It appears that the inside curve is smooth, but that it doesn't follow the same curve as the outside. If you were a famous woodturner, this would be called your signature style. Since you aren't you will have to settle for our criticism of that.
Don't worry about it. Thick bottoms are common with new woodturners. Make a lot of bowls, and the bottoms will become thinner and the walls more uniform. It is automatic. It comes with practice.
The height and shape of the foot is a personal opinion, just as the diameter of the foot is an opinion. If you are making bowls to please other woodturners, they will have smooth round bottoms and no feet. If you are making bowls to please your wife, or anyone else who will use it as a bowl, they will have the stability of a foot. Make them both ways and see which ones you like the best. If you want to make them to give away as gifts, or to sell, make them to please your wife.
And, sometime we have to leave a foot to keep from going through the bottom.
As for that Oak? Wrap some of it in plastic while it is still wet. The plastic will keep it from drying. Set it aside in a warm place to spalt. You will be glad you did. It will be even more difficult to turn because of the hard and soft spots, but you have some of the prettiest spalted wood you will ever find.
I wrote an article on what makes a good salad bowl. You are well on your way.
And always remember, this is just my opinion.
The Salad Bowl
