Christmas Projects...
DWR
>This is a follow-up to the 12" saga from the main message board.
Here are the spindles that were cut on the modified jig, rather than swapping in a 12" blade.
I still need to finish machining the bases and tops, but one is done and the rest will be finished tomorrow.
They will hold both a pillar and a taper candle... Each is turned a little differently and the tops and bases are Walnut, Cherry and Curly Maple. The spindles are European Beech.
Thanks for all the advise from the main board...
Dave
