Epoxy Play
Epoxy Play
Epoxy Play
Bob Edwards
>This is a piece of ash that had gotten rather punky(sp). The red hart shape was a worm hole. I colored the hole with felt tip marker and filled with clear epoxy. I thinned the extra epoxy with acetone and coated the inside of the box and the lid. I am always looking for a water proof finish. This may be it. The lid is a piece of Corian.
Re: Epoxy Play
Re: Epoxy Play
ken chase
>I have often wondered if epoxy could be thinned out and applied like a finish. What kind of epoxy did you use? The kind in a cylinder you get at the hardware store or a two part to be measured then mixed?
Did you use a brush to apply? Was it smooth or did you have to sand afterward?
Thanks
Re: Epoxy Play
Re: Epoxy Play
Bob Edwards
>Ken, I applied it with my finger in a rubber glove. There was a bit of open, punky grain on the inside and I wanted to work it into the wood as much as possible. It dryed clear and shinny. No sanding required. It was a two part 15 minute epoxy and took over 24 hours to dry hard.
