Perfect Vacuum
Perfect Vacuum
Perfect Vacuum
Jorge Castaneda
>All this timely talk about vacuum systems gave me the kick I needed to complete mine. I got most everything needed a couple months ago and then my bread making work kept me away and plain forgot about it, so yesterday after reading some I gave my projact a hard look, figured out how everything should fit together and decided I needed an elbow to make it easier, a local auto parts store had it, so with no more excuses, it got assembled, a bowl was put in place held by the tailsotock, the vac pump switched on and in a very short time it read 28, so I took the tailstock away and the bowl was spinning true, by now the gauge read a little over 29, Yikes!,the joys of living at sea level, so had to let some air in, lowered the gauge to 15; just to test,I thumped the bowl and it did not budge. So I am pleased with the results so far, but in Jeff Jilg's article he talks about intake filters to protect the pump from saw dust moisture etc, what do you use for a filter and where did you obtain it? or how did you make it?
Inquiring mind needs to know... I want to finish the job before giving it a workout.
Thank in advance
Jorge
Re: Perfect Vacuum
Re: Perfect Vacuum
Mac
>Hi Jorge, I got my filter at Surplus center,looks like a cartridge type,like would be used on any air line.I suspect that auto supply places would have something that you could adapt.Any that would go in the line ahead of the pump will work.Even a place like Home Depot (ugh)might have one.
Re: Perfect Vacuum
Re: Perfect Vacuum
Jorge Castaneda
>Hi Mac,
I'll be in Ellsworth tomorrow and look for it.
Thanks for te info, and happy holidays to you!
Jorge
Re: Perfect Vacuum
Re: Perfect Vacuum
Mike Schwing from Md.
>I think your gauge might be a little ambitious. Still, I'm sure it works great even if its on the high side.
Re: Perfect Vacuum
Re: Perfect Vacuum
Jorge Castaneda
>Hi Mike,
I think you are right! : )
Re: Perfect Vacuum
Filters
Bob Hackett(Mainely,Bob)
>You could use an in-line fuel filter from any auto parts store(I use a glass bodied motorcycle fuel filter I had laying around).John Nichols used to use and promote a filter made from a short section of pipe with caps on the ends and filled with a shop rag.When it started to lose vac pressure or became slow it was time to pull the rag and shake it out.
Either of these or a dirivative will get you going till you can get a whiz-bang model like Mac has (he`s always been a slave to fashion).
Mainely,Bob
Re: Perfect Vacuum
Re: Perfect Vacuum
>Jorge I'm probably going to the extreme but I need a place to store my faceplates and tool rests so I'm going to build a cabinet that sits to the left of the headstock on the floor. It will house the vacuum pump in the top in an enclose area with filtration and I may even put in a cooling fan because my pump gets quite warm with continued use. That will be in the top of the cabinet. In front of that will be a short drawer and below that will be 2 more drawers. These will be used to store the vacuum chucks, other faceplates and tool rests.
Re: Perfect Vacuum
Re: Filters
Jorge Castaneda
>Hi Bob,
That is what I was thinking, a call to the local auto parts came with an on line gas filter, all they had in stock is for 3/8" line, but one for a 1/4" will be here first thing tomorrow.
Gracias
Jorge
Re: Perfect Vacuum
Graet Minds...
Jorge Castaneda
>Think Alike!
John,
That is what I am building today, a low cabinet to the left of the headstock, at the lower compartment, the pump and spare oil and 1/4" line, in the middle the vacuum assembly when not in use, the top compartment the vacuum chucks and faceplates and the top of the cabinet for tool rests, that will give me a better work conditions, right now there is lots of stuff piled behind the headstock.
I have not run the pump continuosly, so I don't know if it will get hot, but as long as I am in the middle of building, I will think a way to make a provision for forced ventilation, thanks for bringing it to my attention.
Gracias
Jorge
Re: Perfect Vacuum
Re: Filters
Bill Howatt
>Jorge,
That is what I use. Mine is a small metal cannister and I recall them being popular many years ago; I got it in a surplus store. I shoved some filter material that looks similar to coarse cloth into the pipe in front of the filter so it would catch any coarse stuff perhaps even small splinters that I thought might damage the filter element inside the cannister.
Bill
Re: Perfect Vacuum
Re: Filters
Jorge Castaneda
>Hi Bill,
That cannister sounds like the way to go, I'll try to find one.
Thanks
Jorge
Re: Perfect Vacuum
John
Jorge Castaneda
>A tought came while working on the cabinet, this pump's exhaust comes out through the handle. Will this exhaust be objectionable to breath or will it affect finishes? A rig with tubbing to carry it out of the room comes to mind. Is this overkill?
What is your experience?
Thanks
Jorge
Re: Perfect Vacuum
Hey Jorge!
Dominic Greco in Richboro PA
>Jorge,
I use an in line filter as sold by McMaster-Carr. It's a lot like the one sold by Surplus Supply. I've installed this filter about 3 years ago when I first built my system and so far it's worked out great for me. I'll attach a picture of my vacuum pump set up to this post.
You're talk about bread baking has gotten me thinking. With the onset of the colder weather, I like to bake bread as well. One small problem. My Mother's (my Grandmother's originally) recipe makes about (11) loaves. It all has to do with coming from a large family. We never did ANYTHING small.
And I know someone will suggest cutting the recipe in half (they always do). But what's the fun in that? If you're going to be inside baking bread, why not make enough for several weeks worth? :>) After it's done baking, I set it out to cool, seal it in air tight bags, and freeze it. I can also freeze the dough and that it out when the mood for fresh bread strikes me.
Ahhhhh! Nothing says "Home!" like the smell of fresh baked bread.
See ya around,
Dominic
Re: Perfect Vacuum
Re: John
>Jorge I've run the hell out of mine with no problems that I can tell. I never thought it might affect anything. The exhaust should just be air I think
Re: Perfect Vacuum
Hey Dom
Jorge Castaneda
>That is a neat set up you made, I learn a lot more from pictures than from words, thanks for showing it.
Gracias y
Feliz Navidad
Jorge
Re: Perfect Vacuum
Re: Perfect Vacuum
JimQ
>While the subject is vacuum chucks, does any one know if there is one that can be adapted to a Delta Midi?
JimQ
Re: Perfect Vacuum
Re: Perfect Vacuum
>As long as your spindle is drilled thru there`s no reason you can`t cobble up an adapter for any lathe you wish.See the archives for info on how to roll your own.
I used a combination of brass and PVC fittings and a double sealed ball bearing to make mine.It doesn`t thread on,just slides inside the spindle and seals with an O-ring.
Mainely,Bob
