Another vacuum pump question
Gary Evans, Tallassee TN
>I wonder if someone could shed a little light on the different types of vacuum pumps? Vane-type pumps were referenced in the earlier thread. Today I looked at a used Sargeant and Welch pump that had an oil reservoir between the motor and the pump. I've heard mention of oil-bath pumps, but don't know what that means exactly.
Any info would be appreciated. I intend to buy a vacuum pump when I find a good deal, but I'd like to know a little more about them. References to online articles would also be helpful.
Thanks,
Gary
Re: Another vacuum pump question
Don O.
>Gary, try thomaspumps.com or gastmfg.com for more info. If I remember, the Thomas sight had an area on how the different types work. My understanding is that oil-bath pumps work very well and last longer, but need more frequent maintainence than oil-free pumps. One of the most important factors to consider when looking at vacuum pumps is CFM of air movement. Levels of vacuum pulled by a pump are less of an indication of holding effectiveness than CFM (cubic feet per minute). To clarify, a pump that can pull a high vacuum with a low cfm will take longer to reach that vac level required to hold the work piece and may not be capable of keeping up with leaks in the system or wood. A higher CFM pump will be able to overcome leaks and porous wood. As you have probably seen in other threads, the actual vac required to hold a piece on a lathe is not as high as one might think. That is why you need a bleeder valve to add a controlled "leak" to the system. Too much vacuum can actually blow a piece apart. The forces acting on the wood can be huge based on surface area.
There is a well-known vac chuck article that gives much more detail. I think it might be found in the articles either here or maybe at woodturningonline.com.
Good Luck and Merry Christmas, Happy New Year !
