Choosing a lathe
Don Erickson
>I am considering buying a 1553 Vega Lathe and can't find any info on it. Can anyone tell me anything about this lathe?
Choosing a lathe
Don Erickson
Re: Choosing a lathe
Rick Allen
>That is primarly an arcatecual lathe. Made for folks who primarly turn spindles for a living. This is a good lathe for that purpose. This is not a good lathe for hobby or artistic woodturning. If you want to get into turning because it sounds like fun then I would sugest one of the many hobby lathes.
Please note that along with the lathe you will need hands on training, safety equipment (a face shield and dust protection), sharpening equipment, turning tools, chuck.
>I believe that Bill Grumbine has the Vega bowl lathe (2600?). That's a big price for the 1553. You could get a Powermatic 3520 B for that price - with the short bed extension.
Don Erickson
>Rick,
Thanks. I own a small bat company and have been turning bats on a 1442 Delta with a Vega duplicator. I get vibration with the Delta (even with a Oneway steady rest) so I am considering buying the Vega lathe (I have been pleased with the duplicator). Currently, it takes me about 30 minutes to turn a bat (I'm still a novice). Do you have any advice for me to speed up the process? Will a more powerful lathe like the Vega help?
Don Erickson
>Don I doubtif a more powerful lathe will help but a better quality one might. I'm guessing your problem with chatter has more to do with the cutting tool and more likely the steady rest. When I was at the Louisville Slugger plant they have a steady that automatically comes up after the tool rough shapes the bat. It is a 2 wheel steady and goes exactly opposite the cutter to counter act the pushing force of the cutter. I couldn't see thier cutter well so I couldn't tell how it was cutting.
If you are using a copy attachment I'm guessing the forces won't be the same as those of a cutting tool since this is more of a scraper. I've been expermimenting with reducing chatter on long thin spindles using cutting tools and it's pretty easy to reduce the chatter with my fingers exactly opposite the pressure of the bevel and also taking very light cuts with a sharp tool.
I would think a scraper would change the chatter quite a bit from the way a cutting tool does. The wood may bounce up and down as well as in and out. With a cutting tool it's more of an in and out away from the cutting edge. Try changing the position of your steady rest if that's possible. I think rotating it around the spindle or possibly building one that has 3 wheels. One on the top bottom and back would help.
RussFairfield
>I am not saying that the Vega is not a good lathe, but I would recommend that you consider the new Powermatic 3520 with the 50" extension that is available for it. This would be a big step up from the Delta, and for about the same money as the Vega. Besides it being a more versatile lathe for doing other things, the cast-iron of the Powermatic has better vibration damping than the fabricated steel of the Vega.
Personally, if I were serious about getting intop the commercial bat turning business, I would find a way to afford the bigger 4224 Powermatic. It will cost more, but you might not need the extension, and it has a 3hp drive.
>Russ I would agree but the 18" extension would probably do the job. I have that and if I remember correctly I have about 42" between centers.
