Fogging Facesheild
Fogging Facesheild
Fogging Facesheild
Dave in the PacNW
>Since the weather has turned cold, my shop stays about 65 degrees. The problem that I have is my facesheild keeps fogging up. I use a Dust Begone mask and have no trouble with my glasses fogging, just the facesheild. I tried warming the sheild, that works for a short time only. Has anyone found anything that will prevent fogging?
Thanks in Advance
Dave Anderson
Re: Fogging Facesheild
Bounce
>Or any of the other "dryer sheet" fabric softener products I've tried will work.
M
Ruth NIles
>Try spray wax, like Pledge, it really cleans glasses nicely, too, and eliminates the glasses or flaceshield from become magnetized.
Armor All wipes...
Scott Hurley in N. VA
Jim King
>Ruth: I never heard of this one but I will try it tomorrow. Bounce we dont have and dont expect to see it for another hundred years here but furniture polish is available. Thanks
JKJ in East TN
>As well as their popular windshield treatment, Rain-X makes an anti-fogging product for windows and mirrors. While it does prevent fogging, the problem I found is the moisture still accumulates but just spreads out and the view is still not as clear as I like.
Another thing that works very well for me is a different type of face shield. I have one that is an industrial filtering mask with full-face protection. A molded baffle inside fits around the nose and directs exhalation away from the shield and out a valve so the mask never fogs. A side advantage of this is you can swap the particulate filters for volatile chemical canister filters if you need to spray nasty insecticides or herbicides.
Another option is one of the powered filter masks. I have a Trend which blows a steady stream of filtered air from above and prevents fogging.
Both of the mask options have the advantage of nicely filtering the dust from the air as well!
Jack Savona
>Don, I use the Bust-B-Gone with my face shield. Occasionally, I have the face shield fog up. As soon as I readjust my mask (tighten the nose clip, move the strap up higher, etc.) the fogging clears up.
Hockey Trick
Jim Shaver - Oakville, Ontario
>Hi,
The guys I play hockey with who wear visors have a trick that works. They wipe on some shampoo on the inside surface of the visor then wipe it off, it works very well.
Take care,
Jim
Carole in VA
>Jim, do you even have clothes dryers there? No dryers, no need for Bounce! LOL
Dave in the PacNW
>Thanks to all, I now have several things to try
Dave Anderson
Re: I do remember spitting....
JamieDonaldson
>.. on our diving masks back when I did such crazy things, but that practice has probably been made oblolete whth some spray-on stuff.
Jamie, EPA has made spitting illegal :-)
Clem Wixted
JKJ in East TN
>>...some spray-on stuff.
There is some excellent treatment in a bottle available at the dive stores. It appears to be a light soap solution. I did a lot of cave diving in Florida springs and also some cold water diving in TN and this stuff worked far better than the traditional method.
BTW, I still have a dry suit, double tanks, and all the gear for cave diving if anyone is interested. These days, I'd rather ride around on my tractor.
Actually, It Was Not EPA...........
Barry Turner
>Actually, it was public health that was responsible for laws against "spitting on sidewalks" as an effort to help control TB (tuberculosis) that was running rampant in this country 40 or 50 years ago.
I suspect that it is still perfectly legal to spit on one's own face shield........as long as the face shield is the only object that is contaminated.
