Speed
Blake Washburn
>I'm a brand new woodturner! I got my lathe yesterday (12/20/05). I was wondering how fast I should have my lathe running when I'm roughing out a blank.
Speed
Blake Washburn
Re: Speed
Sean Troy
>You start out as slow as possible and as the turning gets balanced, you increase the speed accordingly.You can tell by the lathe vibration. No vibration means you can turn up the speed till it starts to vibrate and then back off the speed just a bit till it stops.
Re: Speed
David Breth
>Two safety rules:
Make sure you check the speed setting on the lathe before you turn it on. You don't want Tuesday night to have concluded at 1200 RPM because you got something running true and increased the speed, then come back Wednesday, chuck up a new unbalanced piece, and have it start off at 1200 RPM.
Also, before you turn on the lathe, make sure the blank is clearing the toolrest, and make sure the blank is clearing the ways. If the piece is unbalanced and needs to be roughed, it would be a good idea to put it between centers for a little while anyway, to give some stability.
Lastly, whenever you turn on the lathe with a new piece loaded, stand off to the side when you turn on the machine, so if it flies off of there, you are not in the path.
David B.
Re: Speed
Mike Schwing from Md.
>The other responses were spot-on. The ohter thing that came to mind is that when I started out I sometimes had a frustrating occurence of "ripples" in my work, even during roughing out. Oh, before I forget, roughing is a WONDERFUL opportunity to practice different cuts, gouges, approaches, etc... don't neglect the available work surface in a rush to get a rough out finished. Back to the ripples - this type occurs when you move the gouge faster than the revolution speed will allow for a continuous cut. Move the gouge more slowly or speed the lathe up a bit.
Other ripples can occur from flex, but they're not what I was intending to discuss.
Beware the flying bowl! Stand out of the line of fire till you're sure of the integrity of your workpiece, and even then, be a bit extra careful. I almost lost an eye last week on a piece I was relatively sure of and out of the line of fire.
Re: Speed
David Breth
>He's not kidding about the eye - Mike posted about his incident several days ago. Gotta be careful. Faceshields!
Re: Speed
Raymond Overman in SC
>Since you're new, let's start at the beginning.
Between centers (A spur in the headstock end and a live center in the tailstock end) should be started slowly to eleviate as much vibration as possible. An extremely out of round piece of wood will literally walk your lathe across the floor unless it's really weighted down. Take the previous advice of checking your clearances and standing out of the path of the spinning piece when starting the lathe.
Faceplate turning or worm screw turning can give a little more stability in out of balance roughing but still start with your tailstock if possible. It may prevent the piece from coming off your lathe but won't keep your lathe from dancing.
Be careful when using spalted wood, figured burls, or crotches because of unseen cracks or weak spots in the wood. Do not stand directly in the path of the spinning wood.
Turning speed has a lot to do with comfort. There is a level of speed required to make the cut without bogging down the motor, especially while roughing. I don't believe there is a one size fits all formula for your lathe, your turning style, your specific blank. It's your comfort level with the piece that should determine the speed.
You can always speed a piece up if you're comfortable with it. It's hard to get back to the lathe when it's flopping around your shop like a fish because it's overloaded with an off balance piece at full speed. Start slow and speed it up as you feel comfortable.
I don't have an RPM readout on my lathe. The readout is in Hz. I rarely run my lathe over 35 even when I do finishing cuts because it just doesn't sound right above that. The pulleys at the motor and the headstock aren't the same size so I have no idea what the RPMs are and I haven't taken the time to figure it out since I know where I'm comfortable with the lathe.
Re: Speed - FAST
Rick Allen
>2" spindle 1200 - 2400 And I would likely start at 1800.
6" bowl blank 800 - 1800 And I would likely start at 1200
10" bowl blank 500 - 1200 And I would likley start at 1000
The recomended top speed is 30MPH. If you do the math then you find that a 6" bowl blank that is still square works out to 1200 rpm and 1700 rpm once it's round.
Hands on instruction is a VERY good idea. A lot better than watching someone demo or watching a vedio or reading a book or questions and answers on an internet forum. That is my preference for intruction with each step being at least twice as good as the one before. This is to say that hands on instruction is easly 4 times as good as a vedio. You can watch a vedio 100 times and still not get close to the benifit you will recieve from hands on instruction.
Re: Speed
Keith Tompkins
>Blake, you didn't mention if the lathe is variable speed....that's important. If not, use lowest speed possible, balance the piece as well as possible before firing it up, and stand to the side.
Consider a few lessons to speed things up..good luck.
