REAL MILK PAINT
mini sanding mops - testamonial *LINK*
Mike Schwing from Md.
>Unsolicited, unpaid testamonial to follow:
I have been searching the world over for the perfect sanding solution for concave surfaces that are too small for cushion backed sanding discs and often have irregular curved surfaces that normal sanding discs, even down to 1" diameter would alter or dig in to. Mostly I need this for the bowl of hand carved spoons, but much of my off the wall woodturning/carving would benefit from a similar product. I've tried EVERYTHING, and I do mean every product I could find. I'd buy one or two of them and give them a whirl. Nothing worked the way I wanted it to. Hand sanding would take a million years and still leave disappointing results. I've used scrapers, sanders, burrs, discs, yadda, yadda..
I'm done searching. Mini-sanding mops from Klingspor.
They come in 1", 1.5" and 2" versions. I bought a starter kit in all 3 sizes. These aren't your normal flexible sanding discs that tear, wear, dig, and disappoint. They are fantastic, awesome, better than expected, and work perfectly! In short, they're an irregular concave surface sanding dream. I have been mounting them in my Foredom handpiece and using them freehand, but they could be put in a handheld drill, drill press or in a drill chuck on the lathe. The spoon I finished last evening had an interior that was as good as any could be and I was thrilled. The only drawback is that they' work in one direction only due to the arrangement of the mop, but you quickly learn in which direction to approach the material.
They're not going to help you sand a bowl's interior surface, especially one that is still on the lathe, but for anyone doing any custom work on your bowls, carving, etching, flutes, etc.. they will be of great value.
I am thrilled with these little things.
What do you use for this type of work? If your answer was like mine "nothing that satisfies me", I'd bet you'll appreciate these.
Klingspor
Re: mini sanding mops - testamonial *LINK*
Pete Kekel - Kentucky
>Why would anyone in their right mind ever use these things? What I do is to find the right bits of sandpaper in the approximate size needed and then hot melt them all together and then punch a hole in the center and then . . .
OK, I really don't do any of the above. Thanks for the tip, Mike. I've often wondered if anyone ever used those things. Looks like they would help clean up the little bit of carving I do on some occasional pieces.
I use these for tiny details
Carole in VA
>Yellow is 80, red is 220 and blue is 400. Each of the mandrels happens tohave 6 disks on it, but if I need to get into really small crevices I may only put 3 on.
Re: I use these for tiny details
>I'm glad you find them useful, and if you'll email me your address, I will send you the ones I bought at the AAW symposium. I find them to be worthless and frustrating, but I loved them in KC.
Carole in VA
>Mike, I only find them useful when getting right up in the crevice next to a bead and for sanding the bottoms on miniatures. And even then your tool work has to be good! For any thing else, I agree...they are useless. I have some that I am not sure they even have any grit embedded in them!
