Quick Qestion Vaccum pump
kevinT in T Bay
>I know this is in the archieves somewhere. What size of a vaccum pumps should I look for? to build the vaccum chuck?
would a pump that has 25.5" of mercury be good enough?
KevinT in T Bay
kevinT in T Bay
KevinT in T Bay
Re: Quick Question Vacuum pump *LINK*
e
>here's a very helpful link to one of the AAW thread on vacuum chucking:
http://www.woodturner.org/vbforum/showthread.php?t=731
i got my 220v pump from a recycled medical supply place, and for my location i pull max 25Hg.
Thanks e...! very much appreciated
kevinT in T Bay
Re: Quick Qestion Vaccum pump
dick mc neill
>I just bought a 1/4 HP Gast vacuum pump from Surplus.com. The max measure on a pump is 30 inches (cannot be achieved under normal circumstances). What most pumps max production is 26 inches. The larger the chuck the greater the vacuum pull. 25 inches is more than enough for a wood lathe spinning 16 inch bowls. In fact you'll soon add an air bleeder valve to LESSEN the vacuum pull down to 10- 15 inches to protect thin walled objects from being sucked apart from the force of the vacuum.
Dick Parr
>I got this from UPS today (only the pump and filter and mounting plate). I got it off Ebay last week. It is a 220 1/4 hp pump. It was taken out of a service cabinet and looks new to be. The filters are clean.
Keep an eye on Ebay as they go on sale all the time. Some like this one had a buy now so I didn't have to wait on a bidding war. Not bad for $77 including shipping.
Good luck.
Dick in Knoxville
Bob Persing (Skillman NJ)
>Kevin,
When looking at vacuum pumps for lathe chucking there are two specs. that are of interest. One is the maximum inches of mercury (vacuum) that can be achieved and the other is the cubic feet per minute (CFM) or �pumping speed�. Being able to reach 25 inches vacuum is quite good. Pumping speed, CFM, will determine how well you can hold a vacuum if the wood is porous or if you have a small leak at the bowl seal or in your plumbing. The higher the CFM the better but even if you don�t find a pump with high CFM there are ways of reducing the effects of porous wood. A very ROUGH indication of pumping speed comparison can be had by comparing the HP rating of the motor used on the pump. Of the rotary vane type pumps, a � HP unit seems to do an adequate job. A 1/5 or 1/6 HP might be OK but I would think a bit marginal. 1/3 HP would most likely give more than enough pumping speed (CFM) to handle porous wood and leaks.
HTH
BobP
kenny in indep
>Hello, what was the ebay site were you got this set up?, Tnaks for your time, kenny
Dick Parr
>actfastauction was the person I got it from.
Good Luck
Dick
