We value your privacy.
>I just bought a Jet 1236 wood lathe so I can learn to turn.
What is the proper height above the floor for the dead-centers?
It is on the factory sheet metal stand (which I will replace ) and the centers are now 40.5 inches above the floor. This seems low to me, as I would have to hunch down to see well and get a comfortable position with the chisels.
>I have mine so that the spindle is a bit above elbow height.
Back when I had a Jet 1236 I placed it on a platform that I constructed of 2X4's and 3/4" ply. I weighted the lathe with bags of concrete mix on a piece of plywood that sat on those cross members between the legs.
Sorry, but I laughed out loud when I read that you are six inches tall! My advice is to lower your lathe immediately! :)
Seriously, I also like the lathe a little higher than the commonly recommended elbow height. If possible, you should try to put it on blocks temporarily to experiment with different heights so you can see what fits you best.
Hey, if we were all 6" high, imagine how much fewer resources we would consume and how much bigger the world would be. The converse of that... Excuse me, I suddenly feel the need to go for a brisk walk for some exercise.
>for your advice. I'm new to turning and the lathe seemed too low for me.
I'm going to start with elbow height plus 2 inches and use blocks, if necesary, to determine a comfortable height.. Then I'll build a more substantial permanent hefty base for it.
>I am 5'11" high. Put my 1236 on 4x4 timbers (3-1/2" square), plus some 1/2" thick pads of rubber conveyor belt on the floor side of the timbers and height is fine for me.
Also, dismantle stand to remove the angle-iron cross members. Build a plywood box angled to fit that cavity above the angle iron shelf about 10 inches high with a removable lid. Insert the box, using peel & stick rubber bumpers at any contact or potential contact point, then reinstall the angle iron shelf. Fill the box with plastic bags of fine crushed stone (left in bags to ease potential future moving), then install the lid. Added about 120 lbs to my 1236.
Have been happily turing over 100 bowls at the maximum capacity over the ways with this set-up.
