Lacquer Finishing Question
Mark Kauder. Phenix City, AL
>As you all know by now, I finish all of my segemented bowls with lacquer.
My basic process is; to apply 4-5 heavy coats of full strength (not thinned) hiqh quality - High Solids lacquer; allow it to set for 2-3 days then sand with 220-400 until level (no grain/defects showing; then spray a couple more coats; allow a week or more to dry and then sand a polish to completion.
Question: Why is it that with open grain woods (Walnut, Paduak, Oak, etc) I can sand level - so that it is absolutely smooth, and then when I spray it again with lacquer, I will see the grain again??
One of you must know. Russ? Sam Simpson?
Thanks
Mark
Re: Lacquer Finishing Question
Mike Schwing from Md.
>Happens on autos, too! I think you know that however. Confounding it is. Sometimes the lines don't show up for a year, sometimes as soon as it gets wet. Sorry, but I can offer no resolution, just some company.
>You are right, Mike, and thanks.
The ones that show up over time, I understand. Lacquer will continue to "out-gas" for as long as two years. So, in the long term exposure of the underlying defect, is a matter of the coating getting thinner and more closely following the surface.
Thanks again.
How are your various injuries? Are you able to train again?
Mark
Allen Neighbors
>My guess is this: Lacquer melts lacquer. Regardless of how smooth you get it between finishes, the lacquer in the softer areas of the grain is melted by itself, and still penetrates some more. At least this is my experience in using lacquer over the last 25 years. Unless you fill the grain before hand, it will still happen. I used to never clean my spraygun. It had lacquer in it year round. Sometimes I have gone for weeks without spraying anything, and when I needed to use it, I wipe the nozzle back and forth with my finger while I trigger air through it, then spray as I need to. However, with this new, pre-catalyzed lacquer, I do have to put the nozzle itself in a small jar of cleaner for an hour or two every two or three weeks. But, lacquer still melts lacquer. Hope this helps. AL
Keith Tompkins
Keith Tompkins
>Mark, I think that the lacquer that fills the pores of the wood has built up a much thicker layer of finish than the rest of the surface. When you apply additional coats, it dissolves the finish in the pores..which then tries to equalize in thickness with the rest of the surface. A filler designed just for this purpose will help, although it is usually tinted. Not good for segmented work. A clear version is available, I believe.
RussFairfield
>My observation about lacquer is that the thicker areas shrink more than the thinner film. The reason for the grain coming through again is that, as the thinners gas off over time, the lacquer is shrinking, and since the lacquer shrinks more where it is thicker, the wood grain show through again.
Since this evaporation take place over a period of weeks, to years, even the smallest of differences in the film thickness will be accented if we wait long enopugh. Large differences in thickness, like open wood grain will show up in a few days, smaller differences in thickness will take longer.
>That sounds like the best explanation I've ever heard. It can be SO frustrating. I've reworked body panels/boat hulls and decks to such a fine degree that the hands simply cannot discern any difference in a surface, and I read somewhere that the hand can feel .005" difference. Yet within a year of an otherwise "perfect" finish, there are very clear outlines of the invisible/repaired areas.
Tks Re: Lacquer Finishing Question
>Thanks Allen and Russ,
Good explaination, I kinda what I was figuring.
Mark
