Stand for mini lathe
George Tyler,Louisa, VA
>I'm giving my wife a Rikon minilathe for Christmas and would like to know if anyone has a drawing for a base or stand ?? What height should it be ??
Thanks, George
Re: Stand for mini lathe
Jim Shaver - Oakville, Ontario
>Hi, I seem to remember a plan in an AAW magazine a few years back where they made a mobile base/cart for a mini lathe from a sheet of plywood...some one have one handy to give out the issue number??
I have Jet Mini and have the Jet stand, I Love it!!!
Take care,
Jim
sawdustdan
>I made one from the plans in Shop Notes #67. My wife (the turner) is about 5'9" the top is 34" high this seems to be a good height for her. With three sheets of MDF it is very solid.
Dan
Doug Reynolds in Seattle
>George: For a more portable stand see: http://www.woodstore.net/porminlatbas.html. It is a large "box" that sits on a bench and has two drawers. Lathe mounts to the top of it.
Bill Neddow
>George, it is generally accepted that the center point of the lathe head should be at elbow height.
George Fitzpatrick - Springfield MA
>For my midi lathe, I picked up a couple kitchen base cabinets, about 24 inches wide. Placed them so that the outside edges would be 6 feet apart, and then put a kitchen countertop on top of them. Built in a couple drawers beneath the counter top (between the base cabs) and keep my compressor underneath the drawers. Was an inexpensive solution and has turned out to be very usable.
geofitz13
maker of fine sawdust
Re: Sorry
sawdustdan
>I didn't check the spelling very well in my original post above, At my request Ellis edited it for me.
Thanks Ellis
Dan
Bruce Wiseman
>Not to go for the obvious here, but I assume you know that Rikon makes an adjustable base for their mini lathe. I think it goes for around $130. Maybe you can make a deal on the package?
RevDoug
>Made this one in about an hour when my lathe first came in. Based on the rule of thumb that center of spindle should be at the height of the bent elbow. Find that measurement and figure from there. What you can't see in the photo is that there are two 2x4 feet at the bottom of each leg. I also put a strecher in between the legs to steady them. The only thing I want to change is to put a piece of ply on the back side to make it even more ridged. Maybe a shelf for balast would be nice too.
Turn 'em round,
JimQ
>I used a length of 5"X15" GluLam for my bench top. It sure can absorb vibration. It is held up by a 2X6 frame. Since I have the extension on my Delta Midi, I used a 6' length. I have started building a storage cabinet to fit in the base.
I've still got 2 pieces leftover, 6' and 9', if any one in the Phoenix, AZ, area wants one.
JimQ
David Breth
>I'm using an unusual but simple solution. My next door neighbor gave me a small folding/portable workbench he didn't need - can't remember what they are called. Basically it is a glorified pair of sawhorses with a couple of 2x6's on top. The 2x6's can be adjusted back and forth like a vice. I put a larger board on top of it to support the lathe, and on which I can put tools.
It is not a portable solution (unless you take the lathe off), but it has some nice points to it. It will seek a level position, because the legs are a little flexible (so if your floor isn't perfectly level, it won't rock). If a piece is unbalanced, the legs help absorb the wobble, and have rubber feet, so the lathe doesn't bounce around. That doesn't mean it is flimsy, as it is not - this is far sturdier than my previous bench. It also creates an open-lathe space, so nothing really gets in your way when you work.
Someday I'll do this differenty, but for the foreseeable future, I really like the way this rides.
MountainMan
>Hey George
I tried sending you a really nice plan for a lath bench - I am having trouble with your posted e-mail:
gtyler6@juno.com
If you can give me a good address, I'll send it to you...
Regards
Charlie
