Re: Make a bowl spinner
RussFairfield
>Make a bowl spinner. And, it can be used for finishing.
All it takes is a 3/4" shaft that is threaded on one end, 2 cheap pillow block bearings, a couple pulleys and something like a BBQ rotisserie motor for a drive, and an adapter for the threaded end of the shaft to fit your chucks or faceplates. It looks kinda like a cheap home-made lathe headstock.
It can have fixed pulleys. 60 RPM is about right for things in the 6-12" diameter range. Or it can be fancy with a small fractional HP mechanical variable drive. The variable speed works better because the rotation can be adjusted to what works best for the size abrasive being used. You might need more HP than than the turkey spinner for laege forms and heavy rocks.
It makes gloss finishes easier because heavy coats of gloss poly and lacquer won't run if the work is rotating slowly. The variable speed is better for finishes because the speed can be selected to just fast enough to stop the run, but not so fast as to move the finish outward to a larger diameter.
This description is only intended to give someone an idea to tinker with, and make their sanding and finishing a little easier. It is not a how-to article, so there will be no pictures or drawings.
