Ron? What's this about alcohol?
Allen Neighbors
>In the post below, about Hollow Form Thickness, Ron mentioned alcohol. I'm a novice turner. Can you explain the alcohol thing to me? At the present time, I use the soap solution for green wood. Am still experimenting with that. Most boxes warp so the lids don't fit, even turning thi-i-in. Is the alcohol used on green wood?
Thanks for your time, in advance.
Al
Re: Ron? What's this about alcohol?
Carole in VA
>Go to Articles and Reviews, turning section, Dave Smith's article on alcohol drying.
tek-Brunswick, Ohio
>Boxes need to be dry before tuning to final dimensions. If the boxes are turned end grain they warp less. Many box turners will rough out boxes even if the wood is dry and let them sit, a day or two before final turning. Green wood needs to be roughed out and left until dry. I did try the alcohol drying on one box of spalted beech and it worked well.
Thanks Carole
Allen Neighbors
>I appreciate your quick response. Awesome article. I can't believe how smart I'm getting... Just wish it would do me some good... :o)
Anyway, I thank you. (bowing low). AL
Allen Neighbors
>Tek, I also thank you. You may have saved me many, many hours of frustration. I'm going to have to change the way I do boxes. Much appreciated. AL
