We value your privacy.
>I am thinking of buying a background that fades from white to black. How do you position it when shooting turnings? Do you bend it into a cove shape from horizontal to vertical, with the white in front and the black in back? How do you take a shot dead straight on the front of a turning and not pick up the edge of the table it is on or do you always shoot from front and above? Should I use the camera's portrait mode so it throws the background and foreground out of focus?
>Those gradient backgrounds are expensive-be ready for sticker shock! If you do buy one, get a flat black rather than glossy. I once tried to make one with several spray paints, from gray primer to flat black, but it was very difficult to get an even transition in shades. Any background should have an upward sweep from front to back/top, thus eliminating any appearance of edges in the background. You can simulate a gradient backdrop with some lighting tricks which cast a shadow on the background.
>Thanks Jamie; How did your Cleveland Show go? Sorry I couldn't make it over there. That is my neck of the woods, but I was tied up with other things that weekend.
>As Jamie said, you can simulate a faded backdrop with light tricks. Here's a hastily taken photo using a pure white backdrop which is actually laying flat--except for some waviness which I didn't bother to deal with. No upcurve at the back, curving the back up would have caught more light and defeated the purpose. In another pic, I'll show the high-tech setup.
>I'm using a plastic poster sheet, 36" x 42" for the background. That's big enough for a small subject, without too high of a camera angle.
I've seen 4 x 8 sheets of thin flexible vinyl wall covering, white but slightly textured on one side although I think they're smooth on the back--at Home Depot type stores. This would work well for bigger turnings probably up to 3 ft across. They were about $12 last time I looked.
Notice the frugal use of clothspins, foil, a chair, and household diffusion material.
>Thanks Ken It's great what youi can do with a little ingenuity! I may still spring for the background though. My younger daughter is an art major at Kent State University ( ceramics and textiles). She wants me to photograph he ceramics and she likes the gradient background. Ceramics can be worse than wood for showing glare. I'm going to make a white cloth covered booth to diffuse the light.
>I�m glad you posted this Ken. I tried different setups trying to understand how you got the results when you first suggested this a couple of weeks ago. I always had the backdrop elevated in the rear and could not get the result. I will try this setup tonight.
>Remember, that whatever you use as diffusion material will affect the color of the light highlighting the object. As also, the surrounding items you use to bounce light back onto the subject will affect the color.
>Tek I don't know where to find glossy gradient backdrops, I've checked around. I shoot a lot of ceramics. I would learn to do it with a seamless background. The painted fade or graduated backgrounds scratch very easily. I mean very easily. If you shoot ceramic set them gently down on the background and do not rotate them. You will scratch it even with wooden pieces. If it doesn't scratch you will burnish the surface and light will reflect off of it differently so it might as well be ruined. I have about 10 of them right now. I use small sections for jewelry and stuff but the centers are all scratched and useless.
Don't mess with portrait modes or whatever. shoot in either aperture priority or manual and choose the f stop that will give you the depth of field you need to get the piece in focus.
You can gently curve the background over the front edge if you think you will see this edge.
>George I find it easier to just shade the background, and or move it further back. If you use a flat background you can't always shoot at the best angle. Some pieces should be shot at a lower angle. 2 things make a background dark, distance from the light and blocking the light from hitting it in the first place. Depending on the space you can use either one.
>I used a piece of 1/4'' luan plywood , Painted it grey . It hase nough give to it you can get a good arc in the back ,and if you shade the back with something ( i.e. cardboard) you get the same effect more or less . I use some rubbermaide storage totes to difuse the light a bit . I have found the lighting to be the hardest part of the whole deal . ( any hints jamie ? ) or is it just play with the lighting until its right
>If you have only one light, and use a good bounce reflector on the other side--even a mirror--and there are no other lights on in the room, you can get away with using a flat surface even if the back edge is below the top of the picture as long as you can block the light back there.
A camera's narrow latitude of exposure probably won't see that edge if it's back far enough but if a hint of it does show in the image, well, a little digital manipulation in Photoshop will take care of that.
>Thanks John, I will definately have to play with the lighting more. I only had the 500 watt bulbs and it seemed impossible to shade anything as they illuminated the room. In the tent they created a white reflection on the bowl surface and even the PVC tubing showed as a reflection. This week I got 150 and 300 watt bulbs to try but building the house haven't had time to try them yet.
>Bryan, I'm using Jamie's KISS method--one light, and a bounce reflector. Think about painting your panel white, you can still get a nice fade to black if you use only one light with no other lights in the room. Very nice picture, but the multiple shadows add a little distraction to your image.
>No P probably stands for Program mode where the camera chooses both f stop and shutter speed. Some cameras have what is called Portrait mode. this is just another section under the program mode. In portrait mode the camera still chooses both shutter and aperture but will choose a larger aperture for less depth of field. There are also sports mode, night mode and god knows what else. I prefer to choose my own instead of letting the camera.
>George Light bouncing around the room can be a problem. I have several fairly large pieces of cardboard that I use to block the light from hitting the background. My photo booth is an upside down U more or less so I can lean the cardboard against the sides to block the direct light, then if necessary I put another piece on top to block the light bouncing off the ceiling.
When you set up your frames set them up so the cloth is on the inside. This helps keep the PVC frame from showing. If your work is super glossy you will still see a reflection of the panel in the work. There are some tricks to get around that but it's mighty difficult to explain and fairly tough to do. I fight that constantly when shooting ceramics and sometime glass. One simple trick is simply to shoot it before you buff out the final coat of finish. I have one furniture maker who comes to me. He brings his work sanded to 600 grit with one coat of finish. We shoot it and then he takes it home and puts on the final coats and rubs them out. Makes my job a lot easier.
>....for most of my turning photos. The " white house" consists of 1 QH lamp(600w) shining toward the top/R side and bouncing around inside to soften shadows. A 500w QH work light will do the job quite well, and I much prefer to use only 1 light and fill shadows on the bottom L with a bounce card. The backdrop is a vinyl window shade, and I can adjust shading on the background when I want by creating a controlled shadow. This rig is efficient, versatile, and cheap, all principle parts of the Phrugal Photo Studio philosophy!
>Thanks John, makes sense to me, I have the Nikon Coolpix 4500, it has the settings you mention. I have been using aperture priority since you recommended it in past posts.
>John is this still your setup and is the nylon put on each section separately (two side and one top panel? I only have this small photo view. It appears you have two pipes at the upper corner, one to attach the top nylon, one for the side? If that is the case do you see the seams as a dark reflection if not careful?
I like the idea of shooting before final finishing when I want to avoid glare.
>Thanks everyone! It's been a while since I used manual settings on a camera, but I used to do it all the time with my Olympus OM-1. The nice thing about Digital cameras is extra shots don't cost you any film, just a lttle time. With the OM-1 I could still take pictures witha dead battery. I'd just bracket my guess at the proper settings and usually get something usable. I will stick with digital though. I can fix alot of errors with Adobe Photo Elements and don't have to have the right film for the type of light I'm shooting in. My Camera even has a feature to custom set the white balance. Put the camera in The proper mode and take a reading off of a white or gray object and it adjusts the white balance. I haven't tried it yet though. I'm still not quite shure on the different types of background. What is the seamless background made of, and what color do you suggest? It must not be painted because of the reasons John prefers it. I see that there is a lot of intrest in Photo technique here.
>Ken, I had the light on the right side of the booth, pointing up as in Photo #1. Tape sounds like a good thing to do. The baffle is something to try also, I can see the pile of different reflectors one will accumulate.
