How to remove spur center?
gregcm
>I have a JET 1236 lathe that I want to use for pen turning. I can't seem to remove the spur drive that came with the lathe from the headstock so I can insert the pen mandrel. Does anyone have some simple instructions on removing it?
Thanks for any help.
Greg
Re: How to remove spur center?
Carole in VA
>You should have a knockout bar that fits thru the hole in the headstock. Just a tap should knock the spur out, BUT be sure you have hold of it so that it won't injure your hand when it comes out.
don lewonczyk
>Hi, your headstock spindle should be hollow and usually you would take a solid steel bar long enough to go through your head stock to gently tap the spur drive from the rear while holding your free hand to catch the spur drive as it comes free. Some times a wooden dowel will work if it's not stuck to bad. Hope it helps, DonL
gregcm
>Thanks but I have tried the rod and even used pretty hard whack on it with a mallet and nothing. Unfortunately, I bought the lathe in March of 2000 and it has been sittting all this time without hardly any use. I have never removed the spur drive. I live in a dry climate but it still seems to be stuck tight. Can I spray something through the ole in the spindle shaft to loosen it?
GaryG in MD
>Greg,
I have a 1236 too. I have been able to use the "drift rod" that comes with it, but I always remove the spur center when not in use. For other readers, when using the drift rod, always hold a towel (paper or cloth) over the spur center to catch it when it comes shooting out. (Do NOT catch it with your bare hand. DAMHIK!)
You've already tried this without success, so you'll have to try some additional things in addition to hitting it a few more times or a little harder. The problem is that you could damage the bearings if you hit it too hard.
You may have rust or just metal-to-metal bonding. I would try the easy/gentle things first. Try squirting some penetrating oil all the way down the hollow spindle and letting it soak for a while before some more taps. (Marvel Mystery Oil is good, if they still make it.) You could also try to make the spur center very cold. Try putting some ice or dry ice on it. You'll have to tap it out reasonably quickly before the spindle cools down too. Good luck.
As long as we're talking about Jet 1236's, let me give you a couple other tips. Do NOT use the tool rest extender they supply. Throw it away so you won't be tempted. It WILL break, and when it does, you could be injured. Instead, for more flexibility (which you will need), get a MT2 to MT2 extender and use it in the tailstock. [Part # 251-0200 from Craft Supplies for $14, and well worth it!] This gives you the room you need to maneuver the "tool rest body" (banjo)between the work piece and the tail stock. [Then getting the live center out of the extender takes another tool -- I use a small punch and hammer.]
The "off" power switch is hard to use and in a dangerous place. (You have to reach across the spinning work to access it, and it is hard to push.) If you have to turn the lathe off quickly, you can't. I strongly recommend that you make your own safety power switch (a power strip works fine) and mount it with magnets somewhere on the bed at the tailstock end of the lathe.
There is also something in the WC Archive about putting a washer in the tailstock to protect it from being destroyed with lots of use.
Enjoy,
Gary
Bill in Ga
>try spraying WD 40 in the hole
wait for several minutes and then try the bar tapping.
another alternative is to use PB Blaster and spray that in the
hole, and wait and try tapping.
JamieDonaldson
>After the WD-40 spray soaks in, remember the old Peter,Paul&Mary tune"If I had a hammer!" Use the knock-out rod and a 16 oz. "alignment tool"(hammer!)- a sharp whack on the rod should do the trick, and as others have said, don't try to catch the spur in your hand!
Long shot - ice
Carole in VA
>If nothing else works, you can try wrapping a baggie of crushed ice around the spur. It just may chill the taper so it contracts enough that you can knock it free. Wonder how long the spur sat in there before you bought it? Is there any rust anywhere else on the machine.
Curt Fuller
>And once you get it out, remember to wipe both the spur and the spindle morse tapers clean or it'll spin on ya next time you use it.
Arch
>If the remedies for after all else fails fail make a tool that's worth keeping. Saw a nut that fits the spindle in half. Place the halves on the spindle and hold together with a wrench. Unscrew the nut and the stuck center will leave the spindle with no harm to bearings or taper.
When you try driving the center out, spray with WD40 and use a brass rod instead of steel and hit it very sharply and very hard. You will find a ring of rusted corrosion around the center, gently clean it off with oiled used fine sandpaper.
Got It!
gregcm
>Thanks to all for the advice. I got some liquid wrench and sprayed it, let it soak and then put a metal rod through the headstock and whacked it hard with a regular hammer and it came flying out.
Lesson learned. I will remove the taper devices after using and hope to not let my lathe sit unused for so long.
Gerg
Good going "Gerg" :-)
Clem Wixted
Dick Hines
Dick Hines
>Jamie, they look a lot like a Harley wrench, don't they.
