Sanding inside hollow forms & vases
Andrew Bourke
>Hi
I am busy with a vase at the moment and was wondering what devices & tricks can be used to sand the interior. I know some people do not sand the interior of a hollow form but with a vase that is not an option. This is currently a bit of a problem as I cannot get deep enough with my hand to sand properly.
Re: Sanding inside hollow forms & vases
Jim Shaver - Oakville, Ontario
>Hi Andrew,
I think it's TD who places stones inside the hollow form and puts them on a low rpm for an hour or so to tumble sand the insides of thier hollow forms...sounds simple eh!
Take care,
Jim
DWFII
>On my vase, which was also too deep to get my fingers into, I made some curved sticks and ce=mented a little piece of velcro hooking to it. Then I could use pieces of any of the various grits of velcro sanding disks and ended up with a run of Abralon.
Maybe it is obsessive...it wouldn't be he firt time I've been called that...but the inside of the apple vase mentioned below was finished to 4000 grit Abralon all the way to the bottom.
DW
In the High Desert of Central Oregon
Dick Hines
Dick Hines
>Cut a piece of shelving board 3/4" X 3/4" X how ever deep you need to sand. Add some extra for handle. Drill a hole at a 45 degree angle in one end and drill right through the wood at the other end. The holes should be the same size as the shaft of a sanding disc holder. Push the shaft of the disc holder through what ever hole works best and but on a disc and sand away.
Jennifer@Indy.USA
>Jim , I'm not sure who told of this method, but I'm going to try it next time I'm needing to sand the inside of a hollow form. Seems like I haven't been out in my shop in weeks :(.....it will take an entire day just to thaw it out!
Jen
