good dye to mix with epoxy?
Tony
>I need a good dye to mix with epoxy for cracks and holes and stuff. Looking for colors. I guess powdered is the way to go, yeah? I look at the stuff in catalogs and stuff, it makes my eyes cross, so any first hand knowledge would be great, thanks!
Re: good dye to mix with epoxy?
Russell L. Babbitt Jr.
>I know you said colors but for black I use powdered charcoal from any good art supply store....
Fred in NC
>I have used acrylic colors, in the little bottles. It is recommended to use 10% or less of the total volume, or the epoxy might not harden well.
GeeSeaWhy
>I use liquid Transtint dyes, available from http://www.homesteadfinishing.com/ or Woodcraft. Quite expensive at $15 a bottle but these are concentrated dyes. For normal use you dilute them with water or alcohol. Mix just one or two drops into your epoxy.
Graeme
RevDoug
>Do these same dyes work with casting resins?
Turn 'em round,
Pat Mulligan
>I just bought a set of earth tone color pigments from Lee Valley that are supposed to work well with epoxy. Haven't had a chance to try them yet.If you take a rasp to the bark of whatever wood you are using the resulting powder is a pretty good match for filling.
>Tony I use either India Ink or artists chalk that I just crush into a powder. I have used Tempera paint in the past.
Norm Smith in Nova Scotia
>Hi Tony, I use pentel water colours. You can pick up a set of 18 or so different colours for about $10.00 at any art store. They are small tubes but you only need a few drops to colour epoxy. I also have used pigment and other colouring agents but the tubes of water colours are the cheapest.
Norm
thanks guys!
Tony
>Thanks. Good responses! I like the artist chalk idea, and the water color pigments.
I had looked at the transtint dyes but was unsure if they'd work.
Graphite
Jorge Castaneda
>Tony,
For black I like powdered graphite, Gougeon Brothers offers it in their epoxy line of products. For other colors I use powders meant to be mixed with alcohol,from Homstead, a little goes a long way.
Good luck
Jorge
Frank In MantuaNJ
>Use Testor's modle paint just a drop in a half dollar size puddle will give a deep rich color. I did this for years on fishing lurs and it works very well. There are a LOT of colors to chose from. I have used it on a number of turnings and there has never bin a crack or blister, It also sands and will polish if buffed.
