finish question
finish question
finish question
ken chase
>As a design feature I painted a portion of my china berry bowl using a black marking pen. I need a finish to even places where ca glue was used and those places that are bare wood and mat. I worry that if I use lacquer or another solvent based product it will melt the black.
I have considered spraying krylon mat or using water based varnish.
Suggestions will be greatly appreciated. I also wish to conceal some very fine pinholes and crevices that didn't fill thoroughly.
Thanks
Re: finish question
Re: finish question
Jennifer@Indy.USA
>Ken, I spray Krylon Fixatif over my Prisma markers which I think are alcohol based. This sets the ink so that when I put an oil finish on, they don't smear or fade. The fixatif can be found at any good Hobby or Art supply store.
Jennifer
Re: finish question
Re: finish question
Allen Neighbors
>Ken, I now mark some of my more curious looking jigs in my shop with a "sharpie" marker. (Later, I don't have to wonder what I made that for...) As soon as it's marked, I take it into my spray booth and spray with Lacquer. None of them have "bled" so far.
Hope this helps.
AL
Re: finish question
Re: finish question
JKJ in East TN
>>...black marking pen
Did you use a Sharpie permanent marker, waterbased ink, or what? The type of ink might dictate how to proceed.
Regardless, I'd want to do a test before using any method on a piece - use a similar finish on a piece of scrap and mark with the same pen. Then try the lacquer, etc., and see if it dissolves or runs.
Re: finish question
Re: finish question
Mark Kauder. Phenix City, AL
>Ken,
As Jennifer, a Krylon Fixatif will work well.
Optionally, you can spray lacquer on, but spray it very lightly, so that the solvent drys out almost right a way. Do this for several coats, and then apply increasingly heavier coats.
I do this when I have to sign the bottom of bowls with markers instead of my normal burning (like when I turn Ebony or Blackwood).
Mark
Re: finish question
Re: finish question
JamieDonaldson
>I also have tried Krylon acrylic sprays with good results in uses such as this, but test first!
Re: finish question
Re:Ken thanks you all!
ken chase
