turning the bottom of a bowl
Ron in Kingston
>besides using a vacuum chuck what method do you use to turn the bottom of a bowl once the inside and most of the outside are finished, to make the bottom recess etc,
ron in kingston
Ron in Kingston
ron in kingston
Re: turning the bottom of a bowl
Bob Hackett(Mainely,Bob)
>You could use a compression chuck(look on Bill Grumbine`s site) or a jam chuck made from ply or MDF and tape or stretch wrap.Then again you could just turn up a drive drum from scrap and pad it with foam and use your tailstock to turn all but maybe an 1/8" stub on the bottom then finish off by hand.
MB
Russell L. Babbitt Jr.
>If your into spending money you could buy a set of "cole jaws" that are made for your chuck, assuming you are using one. Has it's limitations but works great. This lets you get full access to the bottom of bowls...
Re: turning the bottom of a bowl *LINK*
Ryan Dicker in Renfrew, Ontario
>Hi Ron
Although I agree with Russel about the Cole Jaws, you may consider having a look at the longworth chuck. Step by step plans are available in the articles section linked below. I wouldn't recommend it for larger size bowls, but it works very well with smaller bowls when only a small bit of material is to be removed.
Used all of them
Bill Howatt
>I've used all of those methods to some degree but before I started vacuum chucking I used the donut/compression chuck the most. I think I liked it because it seemed fairly safe and gave total access to the bottom of the bowl that needed work.
Cole jaws
>I`ve seen more than one bowl come out of cole jaws so when ever I use them I always back them up with masking tape or stretch wrap.Few things are as frustrating as spending time on a bowl only to see it bounce off the wall and end up in 2 or more pieces.
MB
Keith Tompkins
>Hey Ron...Kingston, NY? If so, we're practically neighbors!
>I have used all these methods, Sheet of MDFG on a face plate, a blank turned to match the interior with a friction pad and the tail stock, vacuum chuck, and Cole jaws. I made a set of hooks for the Cole jaws to replace or extend the grip out side the circle. They work better than the bumpers.
jared
>Hello: I was considering building one of the longworth chucks. What is your definition of a small bowl. I make a lot of salad bowls that are 12-14 inches in dia. Would the longworth be suitable to use on that size? Thanks Jared
Re:Its hard to beat .....
JamieDonaldson
>...the good ol' el cheapo jam chucks! I turn lots of natural edges, and a flat surface won't work at all on those rims.
Ron in Kinsgton
>sorry it ontario but no too far away
Bill Howatt
>I haven't used a Longworth but 14" dia bowl shouldn't be a problem as long as your lathe has the swing to accommodate the chuck which has to be larger in diameter than the bowl. Apart from Garrett's article which Ryan provided the link there is a good article in the Winter 2006 (current) issue of Woodturning Design on building a Longworth with 6 "jaws".
Bill
Re: Cole jaws
>If I use my cole jaws I start with the tailstock in place for security. Then when I remove that final little nib I pull back the tailstock and remove the nib. You'll find that each method has its limitations.
Re: I made a 20" Longworth with 8 bumpers.
Al Crandall (NE of Indy)
>I think it will hold approx 16" d bowl. I use stretch wrap (flat string) for extra security when the chuck is whizzing along at high speed. Alternating slots stop at about 10" min. diameter while the other 4 go down to about 5" dia. Never had a problem, but I keep most of the pressure from the cuts going toward the chuck. Facing cuts are done very lightly.
GaryG in MD
>Ron,
All the above are good. It's just a matter of how much time and expense and effort you want to put into it and if you want to completely finish the bottom on the lathe or whether you are willing to finish off a small nib with a hand chisel.
I'm ok with the latter, right now anyway. I like the idea of keeping a tenon on the bottom right up to the end. I use a hollow PVC jam chuck (the edge covered with rubber or felt or sandpaper or whatever you prefer) in the headstock to drive the piece, and I got a live center with a long, shallow, conical point (and no cup) for the tailstock. This way, you are always using the exact same center point in the middle of the tenon, right up to the end, and you can turn the nub down, with a small tool, to literally as small as you are comfortable with, depending on the size of the piece and the strength of the wood. Even if you push it too far, it's usually not all that bad because the PVC jam chuck generally stops driving the piece when the pressure on the bottom is removed.
Happy and safe turning,
Gary
