inside out petal vase
bob davis
>where can ifind procedure to create this? bobdavis
bob davis
Re: inside out petal vase
>Send me your snail mail address and I'll send you a copy of an article out of the english Magazine Woodturner. That's the first place I saw this sort of thing. I'm pretty sure it is in my Inside-out turninging file.
Ken Grunke from SW WI
>Bob,
In a nutshell, here's how I did it:
Start with 4 square sticks, temporarily glue or otherwise fasten them together using one of several different methods, which will allow you to seperate the 4 pieces after the first, inside turning step which looks like this on the petal vases I made:
The traditional method for temporary glue up is carpenter's glue with a layer of brown bag paper in the joint to make it easy to seperate with a chisel.
Thin-film double-stick tape works well also, if you apply heavy pressure with a c-clamp for a few seconds to strengthen the bond.
Most woodturners these days have a 4-jaw scroll chuck which can be used to hold one end of the 4-piece assembly, so you only have to bond a small portion of the tailstock end to keep the tailstock point from wedging the assembly apart but also to make it easier to seperate the temporarily fastened pieces after the first stage of turning. Whatever bonding method you use, it's only needed for 50% or less of the total length at the tailstock end to make it easier to pry the segments apart at the headstock end after turning the first stage for the inside profile.
After the inside profile is turned, sanded and finished, seperate the segments, reverse each one so the turned profile is facing inwards, and glue them permanently together so they look like this:
For the final turning on the outside, I would turn a scrap piece of wood in the chuck to an inside curved cone shape which fits the profile of the top inside to act as a drive cone at the headstock end. The tailstock end is held by the tailstock point at the center intersection between the four segments. For padding on the drive cone, I use thin craft foam sheets with peel-off backing available at craft stores or Walmart with the name "Foamies", in 9 x 12" sheets for about 60 cents each. Turn the outside profile to follow the previously turned inside, something like this or whatever your imagination comes up with:
That's basically it--any more questions, ask here.
Vicmarc.fan
>Could you do something on the first glue up to hollow the piece and make the ends?
Ron
>Ron,
The turning on the first glue up, the bullet-shaped form, will end up being the hollow inside after the squares are reversed. Not sure I understand your question, does that help?
>You could simply hollow from the end and then carve the leaves. That's the one quandry of inside-out turning. You can often make similar looking pieces by just piercing the sides. Lets say you just wanted a vessel with 4 hearts in the side you can simply hollow it and then cut out the hearts. The vase that Ken makes can be done similarly by simply hollowing and then carving the leaves. The differene is in the shape of the leaves. With inside-out turning the leaves will have a convex shape on the inside and the outside. If you hollow the vase the inside will be concave with the outside convex.
bob davis
>ken, thank you very much,exactly what i was looking for,bob
