Motor windings
Motor windings
Motor windings
Mike Cunningham (Cape May)
>Recently I read that the windings on some Taiwanese and Chinese motors are not coated and therefore lack some protection. I further read that this can be accomplished by disassembly, dipping the windings in varnish and baking them. Anyone have knowledge of this?
Re: Motor windings
Re: Motor windings
James Brooks in GA.
>All of the wire used in winding a motor aluminum or copper is coated as a single strand. Then when the wire is installed into the stator, leads connected and bound usually by a small cord, the entire motor is dipped into a varnish made for motor windings. DO NOT USE regular varnish. This is placed in a oven to cure. That bonds all of the individual wires together preventing the vibration to rub off the individual coatings on each wire. Grainger sells a spray insulating varnish 1d276 for about $7.00 , That can be used if you desire to disasemble the motor and spray the windings. It may help, but I would replace the motor (when the time comes) with one of better quality.
Re: Motor windings
Re: Motor windings
>Thanks James!
