Spoon, turned for a change
Mike Schwing from Md.
>Some of it at least. Experimenting. Not totally happy with it but someone will enjoy it as a Christmas gift, I'm sure. SURE takes a lot less time to make spoons this way than purely carved, single piece ones.
This took me less than 2 hours total. My fancy spoons take about 10. I think if I put a few well placed beads/coves on the shaft for the next one it would be a nice addition. What'tya think? I also would have liked to put a more decorative accent on top, more like a finial, but I goofed up with the skew.
Turned walnut shaft, maple burl bowl and accent. About 14" long total. Finished by sanding to 320, then Briwax clear. Comments welcome.
Re: Spoon, turned for a change
>Is it decorative or to be used? If it's decorative, I like it. If it is to be used, the bowl is too pointy (he says, ducking and running).
Don Tewell
>I'm a newbie (fairly) at turning. Is the bowl of the spoon turned and then cut in half and the handle glued on? Really a nice piece.
Mike M
>Very nice maybe some off center turning on the handle.
>I lke it, Mike. I assume the bowl is freehand carved, starting with a kutzall, and the handle turned with a round tenon, glued into a round mortise? What are you using for glue?
I may try this myself. I have three from curly purpleheart, one from mahogany and two from teak that I'm trying to get done in time for Christmas, and the plan up to this point was to freehand shape all of them, but they are going very slowly. I may borrow some of your ideas.
Re: Spoon, turned for a change *LINK*
>That is exactly right.
Spoon bowl hand carved with a rotary bit. Not a kutzall this time though. I have been using some of these type bits (below) - solid carbide, 3/4" balls and what not, too. They leave a perfectly clean surface, but can be a bit catchy whereas the Kutzalls are not. They're more sensitive to grain direction, but with burl's changing grain orientation they work well. What I probably like most about them is that they produce shavings/chips rather than dust, so the work area stays clean. They're right fast, too, but they take some learning. Iw would not recommended as a carver's first bits.
I use epoxy for most of my glue needs. It never fails me, whereas others do. I'm going to make more of these, too, I have some design ideas that are too complex for Christmas gifts though.
Woodcarver's Supply
Ed Kelle
>Mike,
You've gotten me spoiled with all those great carved spoons. I agree that this would look better with some more shaping going on in the handle. Or maybe even some texture work. Heck, it is still better than I can do. I'm looking forward to reading your upcoming article.
