220V up and running
220V up and running
Steven Antonucci
220V up and running
steve antonucci
>Thanks to all of you who guided me to wiring the 220V line in my shop. Yesterday, I wired a 30A 220V circuit in about 30 minutes. I had my neighbor check my work before we sealed everything up, and it tested perfect on the first time.
A funny aside- Apparently, the Rikon bandsaw has a soft start. Lots of buildup, push the switch and nothing... momentarily sucked the wind out of me. Then the saw got rolling, and life was good. Comes with a crappy 3/4" blade that I'll be replacing the next time I go out to the garage, but it did cut it's first turning blank yesterday.
Like butta...
Steve
Re: 220V up and running
Good going, Steve!
Clem Wixted
>We knew that even an EE could do it!
Clem
Steven Antonucci
I get to keep my BE (Elect Engg) one more year!
steve antonucci
Ric Taylor
Re: Good going, Steve!
Ric Taylor
>It's wierd the way those things work. I'm rated as a captain on B-747s, but I know almost nothing about flying little Cessnas.
Ric
Dick Hines
Dick Hines
>You mat want to check the AMP draw on your band saw. 30 AMPS sounds like a lot. Am not sure you should be way over in the breaker size.
Glad you got it running though.
Steven Antonucci
According to what I've read...
steve antonucci
>(firstly, it is the thinnest manual I've ever read in my life...)
My understanding is that the power rating on the motor (12.5A) may be exceeded by 50% on startup (old HP printers would draw 18A on power-up, and blow the circuit breakers in the powerstrips- especially if they had their space heaters plugged in under their desks too. :-)
By my calculations, that's about 19A. Rather than "push it with a 20A breaker, I went on size higher. The plug is only rated at 15A. I'm sure that the electricians here would duck and run for cover, but that's the best I could come up with.
Steve
Re: According to what I've read...
JKJ in East TN
>I thought of you a couple of days after you posted the earlier message. I found myself adding a 50 amp 220 circuit and an extension cord for a new welding machine - the first wiring I've added to the panel in this new house.
Something in the back of my mind tells me the factor to use is 125% rather than 150%, but no matter. Electrically, there is no problem with using a higher capacity circuit breaker than needed as long as the wire is sized correctly (extremely important!!!). But remember the breaker is there to protect the wiring, not the device. A breaker sized closer to the needs of an individual motor, which makes sense for a dedicated ciruit, may help protect the motor from a damaging overload, where a circuit grossly oversized will let the motor happily destroy itself. However, I don't think you are supposed to rely on the line breaker for device protection - there should be overload protection on the motor itself to handle this.
BTW, the worst case of circuit breaker/wire size mismatch I ever saw was in the auditorium of a children's camp in central Mexico. Someone had installed over 100 ft of 14 guage wire to a water heater and connected it to a 50 amp breaker! The wire was stretched across the rafters of the building from one end to the other, so the glowing wire would almost certainly have burned down the building in the event of a short. Since neither wire nor breakers could be purchased in the area, I worried about it for a year until I made it back with the right supplies.
