Some bowls I recently made
Eddie Pacheco; San Jose, Ca.
>Last month I took a 2 day turning class in Sebastopol, Ca. and I finally have some turnings to show here. I have an old Atlas spindle lathe which I've "turned" on off and on for the past 5 years. I got wraped up in a home remodel project and later a part-time retirement job that kept me away from the lathe. The remodel is done and I quit the part-time job as it became a fulltime + job. Prior to the class I would start with a decent size piece of wood and an idea in mind and I would end up with a 10th scale version of what I had in mind. On one of my bowls Nancy thought I had turned a knob for a cabinet she was making. That was depressing.
Well last month she treated me to this class as a Christmas gift to me (she's a sweetie) and after a brief layoff for Thanksgiving vacation and to finish a few chores I was able to do some turnings last week. I can honestly say that now when I start with a certain size blank my finished part is close to that size and so far with no launching of the blank from my chuck. And I get real looking shavings now! That is like a super leap of progress on my part.
Anyway, here are the pictures and I would like to say Thank You to you folks here on the turning board. I really have been reading the heck out of your postings and looking at your pictures. And, yeah, you can be sure that I attempted to copy, to the best of my ability, from what I saw here. I hope someday that I can create a piece that someone may want to copy. For now I'll just settle for being able to keep my blank in place from start to finish.
Re: Some bowls I recently made
Bowl 1
>This one I turned at the class and surprising enough, I didn't get a catch using my 3/8" bowl gauge. I also used a Bedan to get to the final wall thickness. Prior to this wall thickness for me was 3/8" minimum.
The wood is mahogony and maple and the size is ^" dia. x 2 1/2" high.
Bowl 2
>This one is from a slab of walnut sapwood that I had stashed in my garage for some reason. The size is 5" dia x 1 3/4" high. The finish is stepped sanding to 400 grit and Minwax paste wax with a terrycloth final polish on the lathe.
Bowl 3
>From the same slab with ths same Minwax finsih application. Size is 5 7/8" dia. x 1 3/8" high.
Bowl 4
>Again same slab and finish process. Size 5" dia x 1 3/4" high.
OOPS! I have an error on pic 2 the size is 8" x 1 1/2" high.
Bowl 5
>Final pice from the same walnut slab. This one has some curl to it and I didn't want to hog a lot of the curl out to make a bowl. I made it this shape as it's a bit easier for me and I couldn't think of anything else at the time. The inner cavity isn't that deep and doesn't go too far into the wing of the saucer as I don't have a curved bowl type scraper yet. This piece of wood had been attacked by bugs and has a few holes in it. The size is 7 3/16" x 1 5/8".
Thanks for looking and thanks for having a virtual hand in helping me to try and learn is craft.
Ed Moore
>Eddie,
You are off to an excellent start. You mentioned using a bedan to finish one of the bowls. A bedan is a French tool used for SPINDLE work, much like a skew. While you may get away with it on the convex portion of the exterior of the bowl, I still would suggest that you use your 3/8" bowl gouge. If you try to use the bedan on a concave portion of the exterior, then it is highly probable that you are going to get a MOAC -- Mother Of All Catches. Your bowl-turning class should have shown you how to make a shear scrape with your gouge. If not, I suggest that you find someone with experience to show you how to make finishing cuts.
Pic #5 does not look like any walnut that I have seen, certainly not black walnut. Are you sure of your identification?
You are off to a great start, keep it up.
Ed
JKJ in East TN
>>Pic #5 does not look like any walnut that I have seen...
Ed, it does look different, but maybe it's the light (from the look of the backdrop, that photo exposure is much lighter than the others). Eddie did say was from a sapwood plank. I had some walnut like that. I cut one walnut tree that was 90% white sapwood with just a tiny dark core!
Eddie, the bowls are great. I made one that looks very much like your last one. Isn't turning fun?! I hope I don't find a part-time retirement job that keeps me away from the lathe.
Ed Kelle
>Eddie
Great job on the bowls. I like #1 & 5 a lot. Happy turning!
Carole in VA
>Eddie,
Wonderful job. I would say the lessons "took"! Keep on spinning.
Thanks, Ed.
>The instructor DID teach and reccomend I use the bowl gouge only on the inside cuts, However, as I got thinner walls I also got less confident in my control skills in doing light cuts with this tool.
I didn't know the Bedan would catch so bad. Great!...now I'm going to be twitching again when I get close to the finish cuts.
On the wood slab. I picked this up at a place called Baker Hardwoods in Gilroy, Ca. which mostly sells walnut. It was laying on the ground and I think the owner said it was walnut with a bit of curl to it. He gave it to me free as I had also purchased some other planks of black walnut. When I got it I had visions of resawing it and making a box. It has been on a top shelf in my garage for 3 years.
The pictures were done on our kitchen counter with a direct overhead incadescant and a small flourescent aimed at the bottom to try and get rid of the shadow. Anotehr area i will need to improve upon.
Thanks, JK.
>It was about 10:30pm when I was taking the pictures followed by a wait as the cameras battery went dead and the backups weren't charged either. After the wait I tried different exposures, but I think my whole lighting background setup needs work.
Thanks for the compliments and like the rest of the turners I like the fact that the start to finish time is way less than flatwork.
I was working at a former vendor's machine shop doing design work, but it soon became clear that the owner was thinking more along the lines of me managing the place for him. I didn't sign on for that and my next batch of 12hr. days, if that ever happens again, will be for something that has my name on the sign. I worked there for 1 1/2 yrs. before quiting in August.
Thank you Ed and Carol.
Re: Thanks, Ed. *LINK*
Ed Moore
>Eddie,
If the instructor said to use the bowl gouge ONLY on the inside of the bowl, and to use the bedan on the outside, then I urge you NOT to go back to that instructor. Further, please contact someone at the Silicon Valley Woodturners, whose site I will post below, and get some help from SVW. Your address is San Jose, which I believe is where SVW is located.
Ed
George Fitzpatrick - Springfield MA
>I especially like #1 and #5. Great job on all!!
geofitz13
maker of fine sawdust
Don Henthorn
>Nice turnings, Eddie, and I love that walnut.
