Bowl sanding
Bowl sanding
Bowl sanding
Patrick Capobianco
>What is the preffered method to sand a bowl, I see devices such as the Sorby sandmaster, or do you use just sandpaper and your hand?
Re: Bowl sanding
Yes
Brian Hahn in SW Wisconsin
>I hand sand.
I sand with an electric drill.
I sand the piece while it is spinning.
I sand the piece after it off the lathe.
I do whatever it takes to get an acceptable surface.
(And some pieces aren't worth the effort and get tossed.)
Re: Bowl sanding
Re: Bowl sanding
georgetroy
>I'm a beliver in the inertia Sanders. I have two 3" ones by Vic Wood. A 2" Angle sander by Sorby and a 2" sander from Steve Worcester. There is much less sanding scratches than from Power Sanding and I do have a complete system there also. Can't do without hand sanding however. GT
Re: Bowl sanding
Re: Bowl sanding *LINK*
Jack Savona
>Here's a detailed description of my bowl sanding procedure. Maybe some of it will help someone out there.
I usually start sanding a bowl with a $29 Harbor Freight variable-speed angled sander using a grit lower than my age. I find that keeps me from discovering problems around the 320 stage. After close scrutiny at the lowest grit, I use either the Sorby 2" or the 3" Rotary sander shown in the link below (as seen in a Raffan video). Between grits I hand sand the bottom of the inside with the grain to avoid swirl marks and then inspect the entire surface for telltale scratches. I also do EVERY grit (e.g. 80,100,120,150....) and by buying discs for 20 cents or less, make myself throw used paper away as soon as it loses its bite.
I used to hate sanding because it seemed to take FOREVER. Now I find that if I make very high demands on myself on the first grit or two, wipe between grits (sometimes with DNA or Mineral Spirits) and do careful examination with angled tungsten lighting, the sanding goes much, much more quickly and I am really proud of my finished piece. When my adult son, who is my most demanding critic, even says, "Good job, Dad.", I KNOW it must be good.
BTY I picked up a small battery powered light: a tiny, bare bulb at the end of a short gooseneck. Sticking that inside a bowl will reveal ANY problems whatsoever. I would think a Christmas (er..Holiday) Tree light bulb a/la/MacGyver would be a perfect substitute. Try it with any tiny BARE bulb and you'll see for yourself, especially on the very bottom of the bowl.
Sandy Claws
Austrailian Rotary Sander
Re: Bowl sanding
Re: Bowl sanding
Wally Dickerman in Arizona
>I agree. I have been using a Vic Wood sander ever since Vic gave me one when I was demoing at Provo. It was the year the Vic introduced them. I've gotten a lot of mileage on it, and it's still going strong.
Wally
