Glueless in Durham
Glueless in Durham
Glueless in Durham
Bill L.
>Having stored CA glue in the refrigerator in between turning sessions , I thought nothing of leaving a 2 ounce bottle of thick superglue in my workshed for the past 2 nights . Well , it dipped below freezing and the glue appears to have irreversibly changed its viscosity to thin . The glue was allowed to warm up to room temperature ; and 24 hours later it still flows like water ! Is there any way of " fluffing" up this almost full bottle , or should I get a permanent marker and replace 'ck' with a big "N" ? I sure miss it for laminating up small bowls . Bill L.
Re: Glueless in Durham
eaglesc
>I keep my open bottles outside all the time and even with the recent cold weather they are just fine.
What seems odd is that it thinned rather than thickened.
Sam Dean
>Same here. Mine always stay outside, all year in an un heated shop, with no problems?!?
Sam
Steve in Durham
>Are you glueless in Durham, NC?
Ric Taylor
Ric Taylor
>I've been using superglue for 30 years in all kinds of conditions, from extreme heat to extreme cold (well below freezing), and I've never heard of this happening.
Ric
Bill L.
>Thanks for the input on the CA glue . I'm a little red-faced at the moment. This afternoon I discovered the glue was back to normal so it was back to the lathe . This is the first this Turner has used thick CA in cold weather - with a change of viscosity . Yep , Steve , it's Durham,N.C.
