Rookie needs help re:chucks and sharpening!
Wayne Leach
>Hi to all:
I am spending the winter near Americus,GA in a 5th wheel at a campground. I have an add-a-room attached where I can "putter" when not on the golf course. UPS just delivered a new Jet mini and last weekend I build a lathe stand for it out of lanscape timbers. I have collected misc wood (oak, maple,pecan & sycamore) and now want to get started turning but need/want a chuck for bowls, boxes etc. and really need help selecting one to purchase and from where??
Also, I have an old grinder made by Black and Decker with 5" x 1/2" wheels (grey)- does anyone know where I could get Alum Oxide-white wheels to fit this. I have a Baldor at home which I will bring in future so just want to get by this winter. Would the grey wheels suffice if I am careful and use a light touch???
Any help/advice would sure be appreciated.
Thanks in advance,
Best regards
Wayne
Re: Rookie needs help re:chucks and sharpening!
JKJ in East TN
>Everyone has their own preference, but I like the Technatool Supernova chucks. I buy them from my local Woodcraft store. They are not cheap, but neither is golfing.
The color of the wheel doesn't matter as much as the grit size. Properly dressed, the grey wheel will work fine but you may want to follow up with a diamond hone if the edge is too rough. I do not know if I would like the 5" diameter since it would put quite a deep concave bevel on the tool something like a bowl gouge might be harder to control. Some people claim 6" is too small but some others grind with 6" wheels. If that was what I had, that is what I'd use.
If your tools are HSS, the generally accepted wisdom is you can't hurt them by overheating as you would carbon steel tools. If the tip gets hot, just don't dip in in water to cool it.
Barbara Gill, Remlik VA
>When our granddaughter showed an interest in turning I bought a Mercury lathe. I got a Talon chuck for it. It is like the Stronghold only smaller, a really nice chuck. So nice in fact that I just bought an insert so I can use it on my lathe when I need a second chuck.
>The oneway talon is a great chuck for that lathe. I have the vicmarc 100 and really like it. Your gray wheel grinder should work as long as you keep the wheels clean. I used an old craftsman 6" with gray wheels for years and then I switched to white wheels and used them until they got as small as 4 1/2". I was still using that grinder until 2 years ago when I bought an 8" grinder. I think the 8" might have been overkill but the wheels do last longer.
