Sandpaper storage solution
Dennis Daudelin
>I recall reading a sandpaper storage question a couple of days ago.
I finally got my digital camera out and shot a couple of pics of mine. Since I've recently built a new shop, I tried to take my learnings of what was missing or difficult from the last shop. Here's how I set up the new sandpaper storage area. It's built into my new tool storage area. It's right behind me as I stand at the lathe.
It has 2 parts. First is a shelf to hold new sandpaper and is covered by a sheet of plexiglass (which of course you can't see as it's clear). The plexiglass keeps the shavings and chips out of this space.
The second part is a holder for partially used sandpaper. This is made by clothespins and wire. The clothespins are labeled by grit so I can put them in the right spot (yes, very anal).
You can also see that I've moved my CA remover to this area so that it's always in arms reach!! I learned something by a recent thread on getting stuck in the wrong place!!
Dennis
Re: Sandpaper storage solution
Bruce in Saint John, N.B. Canada
>Dennis, it sure looks nice and neat... what a great idea! I keep my sheets as well as my velcro backed discs in separate sealed containers labelled with grit size. The reason I do this is that seems to me I read somewhere that sandpaper should be stored in sealed containers otherwise it will take on moisture which isn't good. Can you or perhaps others set me straight on this, is this a fact or did I have a pipe dream?
Dennis Daudelin
>I've never heard about moisture causing a problem with sandpaper other than sheets of it will curl. I've also never had a problem with my unsealed sandpaper but I may be missing something here!
Maybe someone else has an input?
Dennis
>I've never had my sandpaper sealed. I don't have my new storage system in this shop yet but in my old shop the sandpaper rolls hung right overhead on a bar in the open in an extremely damp and humid shop. I never had any problems at all.
Phil Joines
>That was (and maybe still is) true of the old paper that was made from real sand. It used something like hide glue that deteriorates from both moisture and time. Modern papers don't have that problem.
JKJ in East TN
That used to be a problem years ago when the glue used in some sandpaper (especially garnet paper, I remember) would weaken with moisture and the grit would come off easily.
Also, almost no one had air conditioning so high humidity may have been more of a problem in the summer.
