200+ woodworking book reviews
cleaning bandsaw after cutting green bowl blanks
James Gealy
>I have a bunch of green California Sycamore I am cutting up into bowl blanks. I cut the planks down with my bandsaw but the sawdust and sap, though not sticky has gunked up my bandsayw blade. How does one clean a bandsaw blade after something like this? And what does everyone else do for cutting green blanks? Thanks.
Re: cleaning bandsaw after cutting green bowl blanks
TD
>James, first I would suggest that you saw the blanks with a blade made for this purpose. Timberwolf has the best blade that I have used for green wood. When you finish sawing the green wood just saw a piece of dry wood to clean the blade. Let me know if you need the phone number or email for PS Wood who sells the Timberwolf.
TD
Rick in Colgate, Wi
>For cleaning bandsaw blades that are gunked up from cutting green wood I use "Greased Lightning", available at most big box stores. Works on the tires as well.
I do most of my green wood cutting with the chainsaw these days.
James Gealy
>I'm using a 1/2 inch Timberwolf blade but I'm not sure if it is 3 or 4 TPI. I bought it from Lee Valley some time ago and I'm not sure if it was designed for green wood or not. I did try cutting some dry stock afterwards but I did that the next day. My guess is that you should cut the dry stock ASAP after cutting the green wood. I'm going to take the blade off and use some pitch remover to get the dried gunk off. FYI, Lee Valley has a 3/8 inch 3 TPI and a 1/2 inch 3TPI Viking/Timberwolf blade that they say will cut turning blanks but they don't say anything about green wood.
>I hold a narrow piece of maple with a sharp edge up to the spinning blade. I "wipes" all the green residue off. I just tilt the wood at 45 degrees so the freshly cut edge rubs the blade. This is quite safe and cleans the blade well. My bandsaw has a bearing guide system. I am in the process of getting the old style blade guides from the original owner. The bearings get clogges with green wood and they are much harder to clean. I have to bias the blade toward one of the bearing to make the bearing spin and then use the same wood scraper to clean these. The lumps of wood on the bearings make the cuts rough which isn't a problem for cutting bowl blanks but really sucks if you want to then resaw something. I never had this problem with the steel blade guides on my old bandsaw.
pam
e
>Pam cooking spray (unflavored) works well on desolving the sap surgars -- use it on bs and chainsaw.
after, i blow off the bs blade, i re-lub the blade.
Re: cleaning bandsaw "My two cents"
ken chase
>With all due respect to those who recommend the Timberwolf my experience was disappointing and now I buy lenox 1/2" 3 TPI blades from Woodcraft Bandsaw for half the price of Timberwolf. These blades last much longer and have given me better results. (800-582-1328)
P.S. I use a chisel on the edge of the running blade to remove the pitch. Woodcraft recommended kerosine.
I second that
tek-Brunswick, Ohio
>Lube the blade up with pam before you start cutting and cleaning the gunk off will be much easier.
Re: I second that
Pat Mulligan
>To remove really stuck crud from bandsaw blade unplug saw open top wheel cover push a scraper against side of blade below gullets and rotate wheel backwards.Then use Pam-it really works.
Cleaning bandsaw blades--Greased Lightning
James Gealy
>I tried the greased lightning and it took the hardened sap and sawdust of lickety-split. Italso removed the thin coat of lacquer on the blade. I'll try waxing, Pam or Krylon clearcoat.
