New JDS Cyclone
New JDS Cyclone
New JDS Cyclone
David Breth
>I've been saving my pennies for a dust collector, and narrowed my search to the newer cannister varieties such as the JDS 16001, Delta 50-850A, and the Jet version I can't remember the part number of. I was looking at cyclones, but could not find anything that would fit my short ceiling (75") - UNTIL TODAY!
For those of you with short ceilings (and deep pockets), JDS is rolling out a 2HP cyclone, model is 2000-CK, runs $900. It is 72" tall. Amazon lists it as an "order it now and when it comes in you'll get it", so this seems to be a hot-off-the-press item. I don't want to do a commercial for JDS here, but I'll just say the numbers look good to me, and those of you interested can do some research. The biggest thing I wanted to point out is that this is going away the shortest cyclone I've seen that looks credible, and is the ONLY one that would actually fit the height of my basement. Other companies may follow suit, but I wanted to post this because somebody has to be experiencing the same height difficulty I am.
David B.
Re: New JDS Cyclone
Compromises?????
Garrett in Victoria
>Hi David
I hope it works out for you. (I have my shop in the basement but the Pentz cyclone is in an adjoining ground level garage.)
Cyclone design engages some sophisticated physics, and they are the height they are for a reason. JDS is a good company with a lot of experience in industrial DC's, but you might nevertheless want to consider where the compromises were made, and what was done to alleviate the resulting negatives, e.g. how tall a barrel can it accommodate?
Cheers, Garrett
Re: New JDS Cyclone
Oh, and by the way
Garrett in Victoria
>no cyclone nor DC can capture even most of the stuff thrown off the lathe, so if that's your primary intention...
Mine is a 5 HP and I don't even bother to try. A regular sweep up with a broom, BIG dustpan, and garbage pail does that job in my shop.
Cheers, Garrett
Re: New JDS Cyclone
Re: New JDS Cyclone
The Wood Spinner / Bill Hale
>If you are as fortunate as I am and live out away from close neighbors just blow the stuff outside. Rought the exhaust through the wall with a large dryer type vent. I do all my clean up with my vac.
Good turning and be safe.
Happy Holidays
Bill in Casa Grande, AZ.
