Question about oil finishes
Scott Hurley in N. VA
>I recently decided to experiment with pure tung oil on a small maple bowl. As per instructions on the bottle, I thinned some of it with mineral spirits and used that for the first 2 coats. Now, after 2 coats of full-strength tung oil, I noticed that it never seems to dry. I thought pure tung oil would dry after a few days. It's been several days now, and it's continually 'weeping' oil out of the wood. It feels oily, and every few hours, you can see more oil on the surface. How long should I expect the oil to keep weeping out of the wood? Is there any hope for this one? Thanks.
Scott
Re: Question about oil finishes
Barry Turner
>Keep the bowl in a warm place......in the house, not an unheated shop. Keep wiping with a paper towel or soft cloth every day or so. Don't apply any more finish until these two coats are finally dry.
It may take several more days, but I believe it will eventually dry. Next time, don't thin the tung oil quite so much.
Steve Mushinski
>I do not have the answer you are looking for but any oils I have used must be wiped dry. If the wood you are using has large open pours then the oil is sitting in the "straws" and draining out. The used a fair bit of Watco at one time and I did not like that it did exactly what you are talking about for days. I urge everyone that is trying to learn about finishing to take the time to visit "Russ's Corner". The link is in the list on your left. Most finishing questions can be answered with just a click of your mouse.
Steve
Barry Turner
>I think you are exactly right. I used to experience this when I would go into my shop, turn the heat on and once the shop air temperature was comfortable, I would apply a finish. Then I had the "weeping" problem or air bubbles if I sprayed a finish.
What I was forgetting was that although the shop temp was acceptable, the temperature of the wood was still colder. As the wood continued to warm, the miniscule amounts of air inside would also warm......., and expand and push the finish back out of the pores. Make sure the object you are finishing has reached an equilibrium temperature and is at least as warm as the shop temperature, or warmer.
I have great success bringing a bowl into the house overnight. Warming up the shop the next morning and then finishing the bowl. It seems to work even better if the bowl temperature drops a few degrees after applying the finish. Think about it, when the bowl cools, the air inside contracts and tends to pull the finish into the pores of the wood, thereby eliminating the "weeping" problem.
I hope I haven't rambled too much, but this works for me.
David Breth
>I just spent my lunch hour reading Russ's Corner. THANK YOU for mentioning it.
David B.
Carole in VA
>I have asked for his DVDs for Christmas, but knowing my non-wood oriented family, I will end up having to buy it for myself.
>Thanks to all who responded so quickly. I, too, read Russ's Corner today. It has a whole lot of useful info. I'll just be patient with the bowl as it dries.
Scott
